Dell Inspiron 13 5000 Intel Core i7-7500U 16GB 256GB 13.3"
Quicklinx: CG35WS00 Mfr#: 1020340898037
  • Core i7
Marketing description is not available.
  • Ready for the road
    The 13.3" is a popular 2-in-1 size. It's easy to slip into your bag and provides ample screen room to use for hours without eye fatigue.
  • Maximize screen space
    The design emphasizes more screen and less bezel, so your attention's drawn to that brilliant wide-angle display.
  • Designed to impress
    The sleek exterior finish is matched with a smooth, matte inside, offering an attractive, professional appearance, that looks great for any occasion.
  • Get connected
    The Inspiron 2-in-1 is equipped with 802.11ac Wi-Fi for fast, long-range wireless connection with less buffering and drops.
Dell Inspiron 13 5378 2-in-1 - 13.3" - Core i7 7500U - 256 GB SSD
Notebook - flip design
Intel Core i7 (7th Gen) 7500U / 2.7 GHz
DDR4
Storage
256 GB SSD
Display
13.3"
Graphics
Intel HD Graphics 620
Keyboard Backlight
Integrated Webcam
3-cell
32.4 cm x 22.47 cm
Processor / Chipset
CPU
Number of Cores
Dual-Core
64-bit Computing
Intel Turbo Boost Technology 2.0
DDR4 SDRAM
SO-DIMM 260-pin
Storage
Main Storage
256 GB SSD
Display
13.3"
Widescreen
Audio & Video
Graphics Processor
Camera
Resolution
0.92 Megapixel
Frame Rate
30 frames per second
Sound
Two microphones
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
3-cell
42 Wh
AC Adapter
Input
(50/60 Hz)
Connections & Expansion
Memory Card Reader
Yes (SD Card)
Power adapter
32.4 cm x 22.47 cm
35 °C
10 - 90% (non-condensing)
Vibration Tolerance (operating)
RMS (random)
