Dell FPM185 18.5" Rackmount KVM LED Console
Quicklinx: BH11WS00 Mfr#: A7485910
The Dell 1U rackmount LED console provides a system administrator's control station mounted directly into a rack enclosure in a slim 1U (1.75-inch) form factor. Combined with an 18.5-inch flat-panel LED screen and a specially designed keyboard and touchpad mouse, this KMM can manage the setup, administration, and maintenance of multiple rackmounted servers.
  • Ease of installation
    The KMM console supports multiple enterprise configurations. It can be connected directly to the keyboard, video, and mouse ports of a single rackmounted server for a simple one-to-one interface, or it can be attached to a rackmounted Dell KVM console switch. A KVM console switch maintains the electrical connection to each server as the KMM rack console is switched by the KVM among the connected systems.
  • Better for the environment
    The Dell 1U rackmount LED console uses an LED-backlit display and is eco-friendly. Unlike the typical LCD console that uses a display backlit by CCFLs (common cathode florescent lamps), the LED console is free of mercury vapor. The console is also RoHS compliant.
  • Key differentiators
    The FPM185 has two USB 3.0 compliant pass-through ports, which provide faster data transmission between the KMM and connected USB devices. The 18.5-inch widescreen display supports both legacy server video modes and widescreen video modes. The touchpad mouse has palm rejection technology that allows users to rest their palms on the touchpad without causing cursor jumps or page skips.
Dell FPM185 - KVM console - 18.5" - TAA Compliant
KVM console - 18.5"
KVM Switch
USB
Keyboard, touchpad
Aspect Ratio
16:9
Native Resolution
1366 x 768
Colour Support
16.7 million colours
Voltage
AC 120/230 V
Height (Rack Units)
1U
TAA Compliant
Plug and Play, VESA DPMS, RoHS
3-year warranty
Display Type
KVM console / TFT active matrix
Diagonal Size
18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768
Colour Support
Backlight Technology
LED backlight
A-Si technology
Height (Rack Units)
1U
Input
Keyboard, touchpad
KVM
Keyboard / Mouse Interface
USB
2 x USB 3.0 , VGA (DB-15)
Mechanical
VESA Mounting Interface
Spanish layout
Rack Mounting Kit
Included
TAA Compliant
Input Voltage
AC 120/230 V
Power Consumption (Typical)
20 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - replacement - 3 years
50 °C
