Designed with reflective prints on the front panel, the Dell Essential Backpack 15 stands out in low-light conditions, shining brightly when hit with direct light, making you more visible. Good capacity to hold your laptop and everything you'll need for the day. Your essentials will be within reach when you place your phone in the zippered front pocket and carry your water bottle and umbrella within the exterior side pockets. Made of water-resistant outer material with a dedicated, padded laptop sleeve, the Dell Essential Backpack 15 keeps your laptop and other essentials protected. Designed with zippers that can be concealed below the shoulder strap helps in avoiding unwanted attention.
- Dell Essential Backpack 15 - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Black reflective printing with bumped up texture
- 31 cm x 14 cm x 43 cm
- 0.45 kg
- Notebook Compatibility
- 15"
- Water bottle holder, water resistant, zippered front pocket, reflective elements, foam padded laptop compartment
- Carrying Strap
- Hand grip, shoulder carrying straps
- 3-year warranty
- Bundled Services
- 3 Years Basic Hardware Warranty
- Product Type
- 31 cm
- 14 cm
- 43 cm
- 0.45 kg
- 15"
- Additional Compartments
- Umbrellas, bottle, side external pocket
- Carrying Strap
- Closure Type
- Zipper
- Capacity
- 20 litres
- 3-year warranty
- Bundled Services
