The Dell 55 Monitor is designed for convenience and enhanced productivity with easy set-up right out of the box. Great for conference rooms with ambient lighting conditions, the exceptional onscreen clarity and bright images of the 55" monitor provide outstanding views.
The mainstay of the meeting room
The Dell 55 Monitor is designed for convenience and enhanced productivity with easy set-up right out of the box. -
A display as brilliant as your ideas
Great for conference rooms with ambient lighting conditions, the exceptional onscreen clarity and bright images of the 55" monitor provide outstanding views. -
Reliable performance
The expansive 55" monitor is backed with technology, services and coverage that offer reliable performance for everyday use. -
Get the most out of your meetings
Your Dell 55 Monitor - E5515H is just the start. Look for these great accessories when finalizing your purchase to complete your conference room.
- Dell E5515H - LED monitor - Full HD (1080p) - 55"
- LED-backlit LCD monitor - 55"
- Energy Class
- Class A+
- Energy Consumption per Year
- 117 kWh
- USB 2.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.21 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 85% (CIE 1976)
- Input Connectors
- 2xHDMI, VGA
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 124.1 cm x 24.5 cm x 78.6 cm
- 24.4 kg
- Localisation
- United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- RoHS
- Display Type
- Energy Class
- Class A+
- 117 kWh
- Diagonal Size
- 55"
- Viewable Size
- 54.6"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.21 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, sharpness, input select, phase, aspect control
- Anti-glare, PowerNap, Hard Coating (3H), BFR/PVC-free
- Black
- 124.1 cm x 24.5 cm x 78.6 cm - with stand
- 24.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- 2 x HDMI , VGA , Audio line-in , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
- VESA Mounting Interface
- 400 x 400 mm
- Included Accessories
- Remote control, 2 x AAA batteries, 4 screws
- Cables Included
- 1 x audio cable , 1 x VGA cable , 1 x mini HDMI-HDMI cable , 1 x USB cable
- RoHS
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 124.1 cm - depth: 6.48 cm - height: 72.15 cm - weight: 20.3 kg , With stand - width: 124.1 cm - depth: 24.5 cm - height: 78.6 cm - weight: 24.4 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
