For added ease, the Dell Multifunction Printer - E515dw comes with enhanced 1-click features ideal for your everyday printing and imagining needs.
Essential, easy-to-use features allow you to print wirelessly, 1 scan, copy and fax, giving your workgroup added versatility and a boost in and productivity.
Gain peace of mind and additional savings with a dependable and environmentally conscious multifunction printer.
Simple set up
Get your printer up and running easily with the Dell Printer Easy Installer. -
Convenient connectivity
Get flexible connectivity with wireless, USB and Ethernet options. -
Efficiency made easy with Dell Printer Hub
Declutter your desktop with one intuitive interface for all your printing needs. This one-stop, complete solution integrates printer essentials and cloud connectivity for easy document management and control of your printer. -
Hassle-free paper handling
Fax, scan or copy up to 35 sheets hands-free with the automatic document feeder (ADF) and reduce paper use up to 50% thanks to automatic two-sided printing. The E515dw also features a robust cassette input paper tray that helps keep paper free from dust. -
Enhanced copy feature
The "ID Copy" button allows you to copy both sides of an ID card on a single side of paper. -
On-the-go convenience
Print directly from compatible mobile devices with the Dell Document Hub app (compatible with Android, iOS and Windows 8 and later). This printer also supports AirPrint, Google Cloud Print and Mopria, so you can print from virtually anywhere. -
Additional savings
The optional high yield black toner cartridge lets you print up to 2,600 pages for greater savings. For optimal print results, always use Dell original toners. -
Eco-conscious design
The E515dw meets the regulatory and environmental standards, including ENERGY STAR qualification and Restriction of Hazardous Substances (RoHS) compliance. This printer also supports printing on recycled, renewable content and chlorine-free paper.
- Dell E515dw - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 300 - 1000 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 27 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 1200 dpi
- Original Size
- 210 x 350 mm (max)
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thick paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Office Machine Features
- Scan to folder, scan to FTP
- Power
- AC 230 V (50/60Hz)
- 40.9 cm x 39.85 cm x 31.65 cm
- 11.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 10000 pages
- 300 - 1000 pages
- Display
- 2 lines
- Interface
- Standard Memory
- 64 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, Sort
Printing
- Up to 27 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, XPS
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- Fax forwarding
Document & Media Handling
- Max Original Size
- 210 x 350 mm
- 35 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 80 g/m² , Bypass tray - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
- Speed Details
- Printing: up to 27 ppm (Letter A) - B/W , Printing: up to 26 ppm (A4) - B/W , Printing: up to 15 ppm (Letter A) - B/W duplex , Printing: up to 13 ppm (A4) - B/W duplex , Scanning: up to 17 ipm - B/W , Scanning: up to 6 ipm - colour , Copying: up to 20 ppm (Letter A) , Copying: up to 19 ppm (A4)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WPS, Wi-Fi Direct
- Operating System Support
- MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Ubuntu Linux 12.04, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Red Hat Enterprise Linux 6 Desktop, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.9.x, SUSE Linux Enterprise Desktop 11 (32/64-bit), Apple Mac OS X 10.10
- Voltage Required
- 480 Watt
- Power Consumption Standby
- 60 Watt
- Power Consumption Sleep
- 6.6 Watt
- Included Accessories
- USB cable, phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- VCCI, C-Tick, NOM, SEMKO, FCC, R&TTE, RoHS, WEEE, FDA, cTUVus, ERP, ICASA
- ENERGY STAR Certified
- 40.9 cm
- 39.85 cm
- 31.65 cm
- 11.5 kg
- Shipping Width
- 62.3 cm
- Shipping Depth
- 51.7 cm
- Shipping Height
- 49.9 cm
- Shipping Weight
- 15.6 kg
- Sound Emission
- 33 dB (idle) / 50 dB (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
