Dell E2425HS 24" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: HXGXWS00 Mfr#: DELL-E2425HS
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), HDMI, DisplayPort
£136.52 ex VAT
£163.82 inc VAT
The Dell E2425HS is a 24-inch desktop monitor designed to enhance viewing experiences with its Full HD 1080p resolution. The display features a 178-degree horizontal and vertical viewing angle, ensuring that images remain clear and vivid from various positions. With a brightness level of 250 cd/m2 and a contrast ratio of 3000:1, this monitor delivers sharp visuals that are suitable for work and entertainment.
Equipped with Flicker-Free technology and Dell ComfortView Plus, this monitor prioritizes eye comfort, allowing users to work for extended periods without strain. Its versatile adjustments, including tilt, swivel, and height adjustments, provide flexibility in positioning, making it an ideal choice for any workspace. The sleek narrow-bezel design also contributes to a modern aesthetic, while various input options such as HDMI, VGA, and DisplayPort provide compatibility with numerous devices.
  • Clear visuals
    The Dell E2425HS offers a native resolution of 1920 x 1080, ensuring crisp and clear image quality for both work and entertainment.
  • Enhanced comfort
    With Dell ComfortView Plus and Flicker-Free technology, this monitor minimizes blue light emissions and reduces flickering, providing a more comfortable viewing experience.
  • Flexible positioning
    The monitor features an adjustable height up to 130 mm, along with swivel and tilt adjustments, allowing for optimal positioning in any workspace.
  • Eco-friendly performance
    The E2425HS is ENERGY STAR certified and complies with EPEAT Gold standards, demonstrating a commitment to sustainable design and reducing carbon footprint.
  • Multiple connectivity options
    Equipped with HDMI, VGA, and DisplayPort inputs, this monitor ensures compatibility with various devices and easy connectivity.
Dell E2425HS - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Power Consumption (On mode)
12.7 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
8 ms (grey-to-grey), 5 ms (grey-to-grey fast)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.864 cm x 20.946 cm x 38.256 cm
4.14 kg
Pricing Type
BTO
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
151 kg carbon emissions
Plug and Play, RoHS, NFPA 99, BFR-reduced, PVC-reduced
Bundled Services
3 Years Basic Hardware Service with Advanced Exchange after remote diagnosis - Disti SNS
Display Type
Diagonal Size
24"
Viewable Size
23.81"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 84 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Eye comfort mode, narrow-bezel design, Dell ComfortView Plus
53.864 cm x 20.946 cm x 38.256 cm - with stand (lowest position)
4.14 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA
Mechanical
Tilt Angle
-5/+21
Swivel Angle
346
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x HDMI cable - 1.8 m
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
12.7 W
Power Consumption (Typical)
13 Watt
Power Consumption (Max)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 53.864 cm - depth: 20.946 cm - height: 38.256 cm - weight: 4.14 kg , With stand (highest position) - width: 53.864 cm - depth: 20.946 cm - height: 51.207 cm - weight: 4.14 kg , Without stand - width: 53.864 cm - depth: 4.89 cm - height: 32.421 cm - weight: 2.88 kg
Shipping Weight
6.01 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
72.93
Logistics (kg CO2e)
11.33
Use (kg CO2e)
64.02
EOL (kg CO2e)
2.87
Total Carbon w/o Use Phase (kg CO2e)
86.98
PAIA Version
GaBi version 1
Bundled Services
10 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Dell
