Get outstanding value with this 23.8-inch FHD monitor featuring a wide viewing angle, HDMI and VGA connectivity, and an Eco-conscious design.
- Dell E2423HN - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Power Consumption (On mode)
- 16 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 100-240 V (50/60 Hz)
- 55.264 cm x 17.1 cm x 42.035 cm
- 3.85 kg
- Pricing Type
- BTO
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 503 kg carbon emissions
- Bundled Services
- 3 years Advanced Exchange Service and Limited Hardware Warranty
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- 55.264 cm x 17.1 cm x 42.035 cm - with stand
- 3.85 kg
- HDMI (HDCP 1.2) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- VESA screw cover
- Cables Included
- 1 x HDMI cable , 1 x VGA cable
- Pricing Type
- BTO
- Security Slot Type
- Kensington security slot
- Input Voltage
- 16 W
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 55.264 cm - depth: 17.1 cm - height: 42.035 cm - weight: 3.85 kg , Without stand - width: 55.264 cm - depth: 4.969 cm - height: 33.161 cm - weight: 3.11 kg
- Shipping Weight
- 5.29 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 136
- Manufacturing (kg CO2e)
- 341.27
- Logistics (kg CO2e)
- 25
- Use (kg CO2e)
- 134
- EOL (kg CO2e)
- 2.89
- Total Carbon w/o Use Phase (kg CO2e)
- 369
- PAIA Version
- 1.3.1, 2022
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £174.65 |
Other bundles (4)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £159.87 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £33.64 |
Dell WEBCAM - WB3023 | In Stock | £53.51 |
Dell Dell Speakerphone SP3022 | In Stock | £50.73 |
