- Dell E2423H - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class E
- Power Consumption (On mode)
- 16 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 3000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- 55.264 cm x 17.1 cm x 42.035 cm
- 3.85 kg
- Pricing Type
- BTO
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 504 kg carbon emissions
- Bundled Services
- 3 years Advanced Exchange Service and Limited Hardware Warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Wide Viewing Angle
- 55.264 cm x 17.1 cm x 42.035 cm - with stand
- 3.85 kg
- DisplayPort 1.2 , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable
- Pricing Type
- BTO
- Security Slot Type
- Kensington security slot
- Input Voltage
- 16 W
- Power Consumption SDR (On mode)
- 16 kWh/1000h
- Power Consumption (Max)
- 25 watt
- Power Consumption Stand by
- 0.3 watt
- Power Consumption Sleep
- 0.3 watt
- 0.3 watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 55.264 cm - depth: 17.1 cm - height: 42.035 cm - weight: 3.85 kg , Without stand - width: 55.264 cm - depth: 4.969 cm - height: 33.161 cm - weight: 3.11 kg
- Shipping Weight
- 5.29 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 131
- Manufacturing (kg CO2e)
- 340
- Logistics (kg CO2e)
- 25
- Use (kg CO2e)
- 137
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 367
- PAIA Version
- 1.3.1
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £110.82 |
Other bundles (4)
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £15.05 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £35.67 |
Dell WEBCAM - WB3023 | In Stock | £51.99 |
Dell Dell Speakerphone SP3022 | In Stock | £51.33 |
