Dell E2423H 24" 1920x1080 5ms VGA DisplayPort LED Monitor
Quicklinx: HD3DWS00 Mfr#: DELL-E2423H
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), DisplayPort
£80.38 ex VAT
£96.45 inc VAT
23.8-inch Full HD monitor featuring a wide viewing angle and an Eco-conscious design.
Dell E2423H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Power Consumption (On mode)
16 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 3000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
55.264 cm x 17.1 cm x 42.035 cm
3.85 kg
Pricing Type
BTO
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
504 kg carbon emissions
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Wide Viewing Angle
55.264 cm x 17.1 cm x 42.035 cm - with stand
3.85 kg
DisplayPort 1.2 , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
16 W
16 kWh/1000h
Power Consumption (Max)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 55.264 cm - depth: 17.1 cm - height: 42.035 cm - weight: 3.85 kg , Without stand - width: 55.264 cm - depth: 4.969 cm - height: 33.161 cm - weight: 3.11 kg
Shipping Weight
5.29 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
131
Manufacturing (kg CO2e)
340
Logistics (kg CO2e)
25
Use (kg CO2e)
137
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
367
PAIA Version
1.3.1
Bundled Services
10 - 80% (non-condensing)
Accessories (1)
HD3D Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (6)
HD3D Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £14.71
HD3D Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.60
HD3D Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £150.33
HD3D Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
HD3D Dell WEBCAM - WB3023 In Stock £58.40
HD3D Dell Dell Speakerphone SP3022 In Stock £59.88
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort
Brand: Dell
