Dell E2420HS 24" 1920 x 1080 VGA HDMI 8ms Monitor
Quicklinx: FYR9WS00 Mfr#: DELL-E2420HS
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: HDMI, VGA (HD-15)
£131.74 ex VAT
£158.08 inc VAT
Marketing description is not available.
Dell E2420HS - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
19 kWh
Power Consumption (On mode)
11.9 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (typical); 5 ms (grey-to-grey fast)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
55.06 cm x 18.7 cm x 38.91 cm
Environmental Standards
TCO Certified Displays 8
GSA, HDCP 1.2
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class C
19 kWh
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut, Flicker Free technology, Dell ComfortView
55.06 cm x 18.7 cm x 38.91 cm - with stand
HDMI , VGA
Mechanical
Height, tilt
Tilt Angle
-5/+21
Height Adjustment
100 mm
Security lock slot (cable lock sold separately), VESA interface support
GSA, HDCP 1.2
Input Voltage
11.9 W
11.9 kWh/1000h
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Dell Display Manager
Dimensions & Weight Details
Without stand - weight: 3.3 kg , With stand - width: 55.06 cm - depth: 18.7 cm - height: 38.91 cm
TCO Certified
Bundled Services
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
