Dell E2420H 24" 1920 x 1080 8ms VGA LED-Backlit LCD Monitor
Quicklinx: FV9GWS00 Mfr#: DELL-E2420H
Marketing description is not available.
Dell E2420H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/345704
Energy Class
Class C
Power Consumption (On mode)
11.9 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
55.06 cm x 17.1 cm x 41.97 cm
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
431 kg carbon emissions
DisplayPort 1.2, HDCP 1.2
Bundled Services
3 years Advanced Exchange Service
Latitude 5320, 5520
Display Type
Energy Class
Class C
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Flicker Free technology, Dell ComfortView
55.06 cm x 17.1 cm x 41.97 cm - with stand
DisplayPort 1.2 , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
VESA screw cover
1 x DisplayPort cable - DisplayPort to DisplayPort
Input Voltage
11.9 W
11.9 kWh/1000h
Power Consumption (Typical)
15 watt
Power Consumption Stand by
0.3 watt
Power Consumption Sleep
0.3 watt
Included Software
Dell Display Manager
Dimensions & Weight Details
Without stand - weight: 3.25 kg
Shipping Weight
5.95 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
77
Manufacturing (kg CO2e)
296.097
Logistics (kg CO2e)
31.032
Use (kg CO2e)
102.147
EOL (kg CO2e)
1.724
Total Carbon w/o Use Phase (kg CO2e)
328.853
PAIA Version
1.2.6, 2020
Bundled Services
Dell Latitude 5320, 5520
