- Dell E2420H - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/345704
- Energy Class
- Class C
- Power Consumption (On mode)
- 11.9 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 55.06 cm x 17.1 cm x 41.97 cm
- Environmental Standards
- ENERGY STAR Qualified
- Carbon Footprint
- 431 kg carbon emissions
- DisplayPort 1.2, HDCP 1.2
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 5320, 5520
- Display Type
- Energy Class
- Class C
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Pixel Per Inch
- 92
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Flicker Free technology, Dell ComfortView
- 55.06 cm x 17.1 cm x 41.97 cm - with stand
- DisplayPort 1.2 , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- VESA screw cover
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort
- Input Voltage
- 11.9 W
- Power Consumption SDR (On mode)
- 11.9 kWh/1000h
- Power Consumption (Typical)
- 15 watt
- Power Consumption Stand by
- 0.3 watt
- Power Consumption Sleep
- 0.3 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- Without stand - weight: 3.25 kg
- Shipping Weight
- 5.95 kg
Sustainability Information
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 77
- Manufacturing (kg CO2e)
- 296.097
- Logistics (kg CO2e)
- 31.032
- Use (kg CO2e)
- 102.147
- EOL (kg CO2e)
- 1.724
- Total Carbon w/o Use Phase (kg CO2e)
- 328.853
- PAIA Version
- 1.2.6, 2020
- Bundled Services
- Designed For
- Dell Latitude 5320, 5520
