Dell E2414H 24" 1920x1080 VGA DVI LED Monitor
Quicklinx: 91YPWS00 Mfr#: 860-10213
Catch every little detail in Full HD brilliance. The Dell 24 monitor offers sharp, clear images that help make any project easy to complete.
The Dell 24 monitor is the smart choice for making work easy and play entertaining. It offers convenient onscreen access to your peripherals through the available Plug-and-Play VGA and DVI-D ports.
  • Essential features
    High-resolution widescreen 24" display has the features you need to help boost productivity.
  • Outstanding quality
    Rigorous testing and process-quality monitoring help ensure long-term performance reliability.
  • Environment-conscious
    It was built to comply with the latest environmental and regulatory standards.
  • Brilliant clarity
  • Functional and easy to use
    The Dell 24 Monitor is the smart choice for making work easy and play entertaining. Plenty of room to work and play with a 16:9 widescreen format.
  • Comfortable and convenient
    No squinting or craning your neck with the Dell 24 monitor. It's built for comfort.
  • Energy-efficient design
    With 20 W normal-operation power consumption and less than 0.5 W in active-off mode, the Dell 24 monitor can help keep energy costs down, particularly in large deployments. Manage power consumption wisely with PowerNap, which you can enable through the Dell display manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
Dell E2414H - E Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
83% (CIE 1976)
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100/230 V (50/60 Hz)
57 cm x 16.42 cm x 41.83 cm
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
83% (CIE 1976)
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
HDCP, PowerNap
57 cm x 16.42 cm x 41.83 cm - with stand
DVI-D (HDCP) , VGA
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 57 cm - depth: 16.42 cm - height: 41.83 cm , Without stand - width: 57 cm - depth: 4.65 cm - height: 33.75 cm - weight: 3 kg
Sustainability Information
ENERGY STAR Certified
10 - 80% (non-condensing)
91YP C2G 2m HDMI to DVI-D Digital Video Cable In Stock £9.15
