Catch every little detail in Full HD brilliance. The Dell 24 monitor offers sharp, clear images that help make any project easy to complete.
The Dell 24 monitor is the smart choice for making work easy and play entertaining. It offers convenient onscreen access to your peripherals through the available Plug-and-Play VGA and DVI-D ports.
Essential features
High-resolution widescreen 24" display has the features you need to help boost productivity. -
Outstanding quality
Rigorous testing and process-quality monitoring help ensure long-term performance reliability. -
Environment-conscious
It was built to comply with the latest environmental and regulatory standards. -
Brilliant clarity
Catch every little detail in Full HD brilliance. The Dell 24 monitor offers sharp, clear images that help make any project easy to complete. -
Functional and easy to use
The Dell 24 Monitor is the smart choice for making work easy and play entertaining. Plenty of room to work and play with a 16:9 widescreen format. -
Comfortable and convenient
No squinting or craning your neck with the Dell 24 monitor. It's built for comfort. -
Energy-efficient design
With 20 W normal-operation power consumption and less than 0.5 W in active-off mode, the Dell 24 monitor can help keep energy costs down, particularly in large deployments. Manage power consumption wisely with PowerNap, which you can enable through the Dell display manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
- Dell E2414H - E Series - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 83% (CIE 1976)
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100/230 V (50/60 Hz)
- Black
- 57 cm x 16.42 cm x 41.83 cm
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 83% (CIE 1976)
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- HDCP, PowerNap
- Black
- 57 cm x 16.42 cm x 41.83 cm - with stand
- DVI-D (HDCP) , VGA
Mechanical
- Tilt
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 57 cm - depth: 16.42 cm - height: 41.83 cm , Without stand - width: 57 cm - depth: 4.65 cm - height: 33.75 cm - weight: 3 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £9.15 |
