A reliable and affordable 23" monitor with essential features that meet everyday office demands. It features Full HD display quality at multiple angles with VESA-mount compatibility and tilt options, as well as VGA and HDMI ports. It also saves energy with power-efficient features.
Advanced screen performance
View your applications, spreadsheets and more on 23" of 1920x1080 Full HD clarity, with 16.7 million colors, a high color gamut and a 160°/170° vertical and horizontal viewing angle. -
Plug and view
Compatible with legacy and current PCs via VGA and DisplayPort connectivity. -
Mounting possibility
Keep your desk clutter-free by mounting your VESA compatible monitor on the wall. -
Tilt at will
Work comfortably by tilting the monitor forward or backward. -
Convenient controls
Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel. -
Reduced footprint
The Dell monitor features PowerNap technology that reduces screen brightness or puts the monitor in sleep mode when it's not in use. -
Environmentally friendly materials
Your improved Dell monitor is made with arsenic-free glass and a mercury-free LED panel. Its circuit boards are made from brominated flame retardant (BFR) and PVC-free laminates, and it has more than large amount of post-consumer recycled plastics in its chassis.
- Dell E2316H - LED monitor - Full HD (1080p) - 23" - with 3-Years Advance Exchange Service
- LED-backlit LCD monitor - 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - without stand
- 54.48 cm x 5.05 cm x 32.2 cm
- 2.98 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- RoHS, CECP
- 3-year warranty
- Bundled with
- 3-Years Advance Exchange Service
- Designed For
- OptiPlex 3040
- Display Type
- Diagonal Size
- 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, phase, aspect control
- Flicker Free technology, Energy Gauge, backlight dimming control
- Black
- 54.48 cm x 5.05 cm x 32.2 cm - without stand
- 2.98 kg
- Bundled with
- VGA , DisplayPort
Mechanical
- Tilt
- Tilt Angle
- -6/+22
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, VESA screw cover
- Cables Included
- 1 x DisplayPort cable
- RoHS, CECP
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 54.48 cm - depth: 5.05 cm - height: 32.2 cm - weight: 2.98 kg , With stand - width: 54.48 cm - depth: 18 cm - height: 41.5 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell OptiPlex 3040
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £30.34 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
