Dell E2316H 23" 1920x1080 5ms VGA DisplayPort LED Monitor
Quicklinx: BM8HWS00 Mfr#: 210-AFPY
A reliable and affordable 23" monitor with essential features that meet everyday office demands. It features Full HD display quality at multiple angles with VESA-mount compatibility and tilt options, as well as VGA and HDMI ports. It also saves energy with power-efficient features.
  • Advanced screen performance
    View your applications, spreadsheets and more on 23" of 1920x1080 Full HD clarity, with 16.7 million colors, a high color gamut and a 160°/170° vertical and horizontal viewing angle.
  • Plug and view
    Compatible with legacy and current PCs via VGA and DisplayPort connectivity.
  • Mounting possibility
    Keep your desk clutter-free by mounting your VESA compatible monitor on the wall.
  • Tilt at will
    Work comfortably by tilting the monitor forward or backward.
  • Convenient controls
    Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel.
  • Reduced footprint
    The Dell monitor features PowerNap technology that reduces screen brightness or puts the monitor in sleep mode when it's not in use.
  • Environmentally friendly materials
    Your improved Dell monitor is made with arsenic-free glass and a mercury-free LED panel. Its circuit boards are made from brominated flame retardant (BFR) and PVC-free laminates, and it has more than large amount of post-consumer recycled plastics in its chassis.
Dell E2316H - LED monitor - Full HD (1080p) - 23" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
54.48 cm x 5.05 cm x 32.2 cm
2.98 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
RoHS, CECP
3-year warranty
Bundled with
OptiPlex 3040
Display Type
Diagonal Size
23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, phase, aspect control
Flicker Free technology, Energy Gauge, backlight dimming control
54.48 cm x 5.05 cm x 32.2 cm - without stand
2.98 kg
Bundled with
VGA , DisplayPort
Mechanical
Tilt
Tilt Angle
-6/+22
VESA Mounting Interface
100 x 100 mm
Stand, VESA screw cover
1 x DisplayPort cable
RoHS, CECP
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
Without stand - width: 54.48 cm - depth: 5.05 cm - height: 32.2 cm - weight: 2.98 kg , With stand - width: 54.48 cm - depth: 18 cm - height: 41.5 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Dell OptiPlex 3040
BM8H C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.51
