Dell E2225HS 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: HZ8DWS00 Mfr#: DELL-E2225HS
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, VGA (HD-15), HDMI
£77.71 ex VAT
£93.25 inc VAT
The Dell E2225HS monitor offers a 22-inch display with a native resolution of 1920 x 1080. Designed with an anti-glare surface and a 3000:1 contrast ratio, it delivers vibrant images with clear details. The monitor features Flicker-Free technology and Dell ComfortView Plus, which enhances eye comfort during extended use. Its narrow-bezel design maximizes screen space while providing a sleek aesthetic suitable for any workspace.
Versatility is a key feature of the Dell E2225HS, equipped with various input interfaces, including HDMI, VGA, and DisplayPort. It also includes a VESA mount interface for flexible installation options. The height and tilt adjustments enable users to customize their viewing position for optimal comfort. With an environmentally friendly design, this monitor meets ENERGY STAR guidelines and is EPEAT Gold certified, making it a responsible choice for eco-conscious users.
  • Image clarity
    With a native resolution of 1920 x 1080 and a contrast ratio of 3000:1, the monitor provides vibrant colors and sharp details.
  • Connectivity options
    Equipped with HDMI, VGA, and DisplayPort interfaces, users can easily connect the monitor to various devices.
  • Eye comfort technologies
    Flicker-free technology and Dell ComfortView Plus work together to minimize eye strain for long hours of use.
  • Customizable viewing experience
    The monitor features height and tilt adjustments, allowing users to set their preferred viewing angle for comfort.
  • Sustainable design
    Epeat Gold and ENERGY STAR certifications highlight the environmental benefits, ensuring reduced energy consumption.
Dell E2225HS - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Power Consumption (On mode)
11.5 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.2493 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
8 ms (grey-to-grey), 5 ms (grey-to-grey fast)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
50.426 cm x 20.039 cm x 35.417 cm
3.34 kg
Pricing Type
BTO
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
131 kg carbon emissions
Plug and Play, RoHS, NFPA 99, BFR-reduced, PVC-reduced
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Diagonal Size
22"
Viewable Size
21.45"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2493 mm
Pixel Per Inch
103
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 84 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Eye comfort mode, narrow-bezel design, Dell ComfortView Plus
50.426 cm x 20.039 cm x 35.417 cm - with stand (lowest position)
3.34 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA
Mechanical
Height, tilt
Tilt Angle
-5/+21
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x HDMI cable - 1.8 m
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
11.5 W
Power Consumption (Typical)
11.5 Watt
Power Consumption (Max)
21 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 50.426 cm - depth: 20.039 cm - height: 35.417 cm - weight: 3.34 kg , With stand (highest position) - width: 50.426 cm - depth: 20.039 cm - height: 45.417 cm - weight: 3.34 kg , Without stand - width: 50.426 cm - depth: 4.964 cm - height: 29.538 cm - weight: 2.37 kg
Shipping Weight
4.95 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
63.14
Logistics (kg CO2e)
9.3
Use (kg CO2e)
56.85
EOL (kg CO2e)
1.7
Total Carbon w/o Use Phase (kg CO2e)
74.15
PAIA Version
GaBi version 1
Bundled Services
10 - 80% (non-condensing)
Diagonal Size: 22in
Response Time: 5ms
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: Dell
