Dell E2222HS 22" 1920x1080 10ms VGA HDMI DisplayPort LED Monitor
Quicklinx: GM2NWS00 Mfr#: DELL-E2222HS
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), HDMI, DisplayPort
£85.49 ex VAT
£102.58 inc VAT
The essentials you need to be more productive. Get a wide viewing angle while saving desk space. This 21.5-inch Full HD monitor features height adjustability, built-in speakers and an eco-conscious design.
Dell E2222HS - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/605451
Energy Class
Class D
Power Consumption (On mode)
12 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.249 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 3000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 10 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
50.426 cm x 18.728 cm x 35.417 cm
3.9 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
551 kg carbon emissions
3-year warranty
Bundled Services
3 Years Basic Hardware Service with Advanced Exchange after remote diagnosis - Disti SNS
Display Type
Energy Class
Class D
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.249 mm
Pixel Per Inch
103
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Flicker Free technology, Dell ComfortView
50.426 cm x 18.728 cm x 35.417 cm - with stand
3.9 kg
Audio
Speakers
HDMI (HDCP 1.2) , DisplayPort 1.2 , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
VESA screw cover
1 x HDMI cable
Input Voltage
12 W
12.1 kWh/1000h
Power Consumption (Typical)
12.13 Watt
Power Consumption (Max)
21 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 50.426 cm - depth: 18.728 cm - height: 35.417 cm - weight: 3.9 kg , Without stand - weight: 2.36 kg
Shipping Weight
5.11 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
99
Manufacturing (kg CO2e)
316
Logistics (kg CO2e)
24
Use (kg CO2e)
210
EOL (kg CO2e)
1
Total Carbon w/o Use Phase (kg CO2e)
342
Limited hardware warranty - 3 years
Bundled Services
Accessories (1)
GM2N Dell Dual Monitor Stand - MDS19 In Stock £166.08
Other bundles (6)
GM2N Dell Slim DW316 USB External DVD Drive In Stock £35.33
GM2N Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £11.68
GM2N Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £27.80
GM2N Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £135.24
GM2N Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £26.91
GM2N Dell WEBCAM - WB3023 In Stock £46.66
Diagonal Size: 22in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Dell
