Dell E2020H 20" 1600 x 900 5ms VGA LED monitor
Quicklinx: FP7SWS00 Mfr#: DELL-E2020H
Diagonal Size: 20in
Max Resolution: 1600 x 900
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
More than 50 In Stock
£62.78 ex VAT
£75.33 inc VAT
All the essentials, and then some
Maximize your workspace: A thin profilei and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk.
Enhanced views: The 1600x900 resolution is ideal for everyday tasks, while ComfortView is ready for extended viewing periods. It reduces up to 60% of harmful blue light emissions.i
Versatile connections: The E Series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs.
Adapts to your needs: Make your workspace your own with VESA-compatible mounts and stands.
Improved Dell Display Manager
Productive at every level: Dell Display Manager’s (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you’ll get even more preset layouts.
Seamless transitions: The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you’ve unplugged.
The key to convenience: Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
More ways to manage: Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
  • Maximize your workspace
    A thin profile and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk.
  • Enhanced views
  • Versatile connections
  • Adapts to your needs
  • Productive at every level
    Dell Display Manager's (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you'll get even more preset layouts.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • The key to convenience
  • More ways to manage
  • Guaranteed green
    Compliant with the latest Energy Star standards, the E Series monitors meet stringent energy efficiency requirements while in sleep, on and off modes. They're also TCO-certified.
  • Energy reducing
    Save energy with PowerNap, a feature that dims or puts the monitor to sleep when not in use.
  • Clean disposal
    Composting or recycling the packaging is easy since it's made with at least 25% of recycled cardboard.
Dell E2020H - LED monitor - 20"
LED-backlit LCD monitor - 20"
Energy Class
Class D
Power Consumption (On mode)
9.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
47.152 cm x 17.1 cm x 36.896 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
401 kg carbon emissions
DisplayPort 1.2, HDCP 1.2
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class D
Diagonal Size
20"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Pixel Per Inch
94
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
160
Vertical Viewing Angle
170
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Flicker Free technology
47.152 cm x 17.1 cm x 36.896 cm - with stand
DisplayPort 1.2 , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 mm, VESA
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort
Input Voltage
9.9 W
9.9 kWh/1000h
Power Consumption (Typical)
11 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Dimensions & Weight Details
With stand - width: 47.152 cm - depth: 17.1 cm - height: 36.896 cm , Without stand - weight: 2.2 kg
Shipping Weight
3.94 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
100
Manufacturing (kg CO2e)
306
Logistics (kg CO2e)
19
Use (kg CO2e)
75
EOL (kg CO2e)
1
Total Carbon w/o Use Phase (kg CO2e)
326
Bundled Services
Accessories (1)
FP7S Dell Dual Monitor Stand - MDS19 In Stock £166.08
Other bundles (5)
FP7S Dell Slim DW316 USB External DVD Drive In Stock £35.33
FP7S Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £32.48
FP7S Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £135.24
FP7S Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
FP7S Dell Dell Speakerphone SP3022 In Stock £59.71
Diagonal Size: 20in
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: Dell
