All the essentials, and then some
Maximize your workspace: A thin profilei and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk.
Enhanced views: The 1600x900 resolution is ideal for everyday tasks, while ComfortView is ready for extended viewing periods. It reduces up to 60% of harmful blue light emissions.i
Versatile connections: The E Series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs.
Adapts to your needs: Make your workspace your own with VESA-compatible mounts and stands.
Improved Dell Display Manager
Productive at every level: Dell Display Manager’s (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you’ll get even more preset layouts.
Seamless transitions: The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you’ve unplugged.
The key to convenience: Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
More ways to manage: Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
A thin profile and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk. -
Enhanced views
The 1600x900 resolution is ideal for everyday tasks, while ComfortView is ready for extended viewing periods. It reduces up to 60% of harmful blue light emissions. -
The E Series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs. -
Make your workspace your own with VESA-compatible mounts and stands. -
Dell Display Manager's (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you'll get even more preset layouts. -
The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged. -
Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster. -
More ways to manage
Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup. -
Guaranteed green
Compliant with the latest Energy Star standards, the E Series monitors meet stringent energy efficiency requirements while in sleep, on and off modes. They're also TCO-certified. -
Energy reducing
Save energy with PowerNap, a feature that dims or puts the monitor to sleep when not in use. -
Clean disposal
Composting or recycling the packaging is easy since it's made with at least 25% of recycled cardboard.
- Dell E2020H - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/344010
- Energy Class
- Class D
- Power Consumption (On mode)
- 9.9 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 47.152 cm x 17.1 cm x 36.896 cm
- Environmental Standards
- TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 401 kg carbon emissions
- DisplayPort 1.2, HDCP 1.2
- Bundled Services
- 3 years Advanced Exchange Service
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 20"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 94
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 160
- Vertical Viewing Angle
- 170
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, Flicker Free technology
- Black
- 47.152 cm x 17.1 cm x 36.896 cm - with stand
- DisplayPort 1.2 , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 mm, VESA
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort
- Input Voltage
- 9.9 W
- Power Consumption SDR (On mode)
- 9.9 kWh/1000h
- Power Consumption (Typical)
- 11 watt
- Power Consumption Stand by
- 0.3 watt
- Power Consumption Sleep
- 0.3 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 47.152 cm - depth: 17.1 cm - height: 36.896 cm , Without stand - weight: 2.2 kg
- Shipping Weight
- 3.94 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 100
- Manufacturing (kg CO2e)
- 305.96
- Logistics (kg CO2e)
- 18.85
- Use (kg CO2e)
- 74.99
- EOL (kg CO2e)
- 1.2
- Total Carbon w/o Use Phase (kg CO2e)
- 326
- PAIA Version
- 1.2.6, 2020
- Bundled Services
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £129.07 |
Other bundles (4)
Dell Slim DW316 USB External DVD Drive | In Stock | £36.19 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £38.39 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £34.22 |
Dell Dell Speakerphone SP3022 | In Stock | £61.06 |
