Dell E2016H 19.5" 1920x1080 5ms VGA DisplayPort LED Monitor
Quicklinx: BM8DWS00 Mfr#: 210-AFPD
Diagonal Size: 20in
Max Resolution: 1600 x 900
Response Time: 5ms
Interfaces: DisplayPort, VGA (HD-15)
More than 50 in stock
£75.03 ex VAT
£90.03 inc VAT
A dependable and affordable 20" monitor with essential features that meet everyday office demands. It has an HD quality display at multiple angles with VESA-mount compatibility and tilt options, as well as VGA and DisplayPort connectivity. It also saves energy with power-efficient features.
  • Advanced screen performance
    View your applications, spreadsheets and more on 20 inches of 1600x900 HD clarity, with 16.7 million colors, a high color gamut and a 160°/170° vertical and horizontal viewing angle.
  • Plug and view
    Compatible with legacy and current PCs via VGA and DisplayPort connectivity.
  • Mounting possibility
    Keep your desk clutter-free by mounting your VESA compatible monitor on the wall.
  • Tilt at will
    Work comfortably by tilting the monitor forward or backward.
  • Convenient controls
    Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel.
  • Reduced footprint
    The Dell monitor features PowerNap technology that reduces screen brightness or puts the monitor in sleep mode when it's not in use.
  • Environmentally friendly materials
    Your improved Dell monitor is made with arsenic-free glass and a mercury-free LED panel. Its circuit boards are made from brominated flame retardant (BFR) and PVC-free laminates, and it has more than large amount of post-consumer recycled plastics in its chassis.
Dell E2016H - LED monitor - 20" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
47.15 cm x 16.7 cm x 36.89 cm
2.68 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, CECP, TCO Displays
3-year warranty
Bundled with
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, LED edgelight system, adjustable LED power indicator, Energy Gauge, 86% (CIE 1976) colour gamut, backlight dimming control
47.15 cm x 16.7 cm x 36.89 cm - with stand
2.68 kg
Bundled with
DisplayPort , VGA
Mechanical
Tilt
Tilt Angle
-6/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
Stand, VESA screw cover
1 x DisplayPort cable
Security Slot Type
Kensington security slot
19 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 47.15 cm - depth: 16.7 cm - height: 36.89 cm - weight: 2.68 kg , Without stand - width: 47.15 cm - depth: 5.15 cm - height: 27.54 cm - weight: 2.22 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Dell E2016H 19.5 Bundle deal on Dell E2016H 19.5" 1920x1080 5ms VGA DisplayPort LED Monitor
£174.79
BM8D C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.34
BM8D C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £7.85
BM8D C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BM8D C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £24.05
BM8D C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.69
BM8D C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.37
BM8D C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.37
Diagonal Size: 20in
Response Time: 5ms
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 50 - 100
