Dell E1920H 19" 1366 x 768 5ms HDMI VGA LED monitor
Quicklinx: FY9RWS00 Mfr#: DELL-E1920H
Improved Dell Display Manager
Productive at every level: Dell Display Manager’s (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you’ll get even more preset layouts.
Seamless transitions: The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you’ve unplugged.
The key to convenience: Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
More ways to manage: Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
All the essentials, and then some
Maximize your workspace: A thin profilei and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk.
Enhanced views: The 1366x768 resolution is ideal for everyday tasks, while ComfortView is ready for extended viewing periods. It reduces up to 60% of harmful blue light emissions.i
Versatile connections: Our E Series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs.
Adapts to your needs: Make your workspace your own with VESA-compatible mounts and stands.
Dell E1920H - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/342731
Energy Class
Class C
Power Consumption (On mode)
8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
44.54 cm x 17.1 cm x 35.96 cm
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
352 kg carbon emissions
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class C
Diagonal Size
19"
Viewable Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Pixel Per Inch
85
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
65
Vertical Viewing Angle
90
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ComfyView, Flicker Free technology
44.54 cm x 17.1 cm x 35.96 cm - with stand
DisplayPort 1.2 , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 mm, VESA
Security lock slot (cable lock sold separately), VESA interface support
VESA screw cover
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x VGA cable
Input Voltage
8 W
8 kWh/1000h
Power Consumption (Typical)
10 watt
Power Consumption Stand by
0.3 watt
Power Consumption Sleep
0.3 watt
Included Software
Dimensions & Weight Details
Without stand - weight: 2.19 kg , With stand - width: 44.54 cm - depth: 17.1 cm - height: 35.96 cm
Shipping Weight
3.92 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
83
Manufacturing (kg CO2e)
283.49
Logistics (kg CO2e)
1.4
Use (kg CO2e)
66
EOL (kg CO2e)
0.998
Total Carbon w/o Use Phase (kg CO2e)
286
PAIA Version
1.2.6, 2020
Bundled Services
