A reliable and affordable 18.5-inch monitor with essential features that meets everyday office demands. It features HD quality display with VESA-mount compatibility and tilt options, as well as VGA and DisplayPort connectivity. It also saves energy with power-efficient features.
Screen performance
View your applications, spreadsheets and more on 18.5-inch of 1366x768 HD clarity, with 16.7 million colors. -
Plug and view
Compatible with both legacy and current PCs via VGA and DisplayPort connectivity. -
Mounting possibility
Keep your desk clutter-free by mounting your VESA compatible monitor on the wall. -
Tilt at will
Work comfortably by tilting the monitor forward or backward. -
Convenient controls
Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel. -
Environmentally friendly materials
This improved Dell monitor is made with arsenic-free glass and a mercury-free LED panel. Its circuit boards are made from brominated flame retardant (BFR)- and PVC-free laminates.
- Dell E1916H - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 82% (CIE 1976)
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 44.54 cm x 16.7 cm x 35.9 cm
- 2.72 kg
- Microsoft Certification
- Compatible with Windows 7
- Plug and Play, DDC/CI, RoHS, CECP
- 3-year warranty
- Bundled Services
- 3 years Advanced Exchange Service
- Display Type
- Diagonal Size
- 19"
- Viewable Size
- 18.51"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, adjustable LED power indicator, Energy Gauge, backlight dimming control
- Black
- 44.54 cm x 16.7 cm x 35.9 cm - with stand
- 2.72 kg
- DisplayPort , VGA
Mechanical
- Tilt
- Tilt Angle
- -6/+22
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, VESA screw cover
- Cables Included
- 1 x DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 44.54 cm - depth: 16.7 cm - height: 35.9 cm - weight: 2.72 kg , Without stand - width: 44.54 cm - depth: 5.15 cm - height: 26.6 cm - weight: 2.26 kg
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.89 |
Customer reviews
Write a review for the Dell E1916H 18.5" 1920x1080 5ms VGA DisplayPort LED Monitor here!
Item description wrong
Reviewed by Anonymous Review Posted 24/09/2018
This is not 1920 x 1080. It is 1366 x 768
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
