Help improve productivity and add value across your organization with the E1912H 18.5" monitor with LED backlight. Enjoy reliable performance and energy-conscious features that are ENERGY STAR compliant.
Well-designed inside and out
Enjoy vivid, HD graphics on a simple and sleekly styled 18.5" monitor with rounded corners and slim bezel design. -
The picture of productivity
Secure all the essential features you need for reliable office performance, day in and day out. -
Eco-conscious meets business savvy
Technology that complies with some of the latest energy standards is always a wise move for business.
- Dell E1912H - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 82% (CIE 1976)
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 44.5 cm x 16.4 cm x 34.9 cm
- 3.3 kg
- Localisation
- United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- VESA EDID, DDC
- Display Type
- Diagonal Size
- 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- Black
- 44.5 cm x 16.4 cm x 34.9 cm - with stand
- 3.3 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -4/+21
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- VESA EDID, DDC
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- Without stand - width: 44.5 cm - depth: 5.2 cm - height: 26.6 cm - weight: 2.6 kg , With stand - width: 44.5 cm - depth: 16.4 cm - height: 34.9 cm - weight: 3.3 kg
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
