Dell E1715S 17" 1280x1024 5ms VGA DisplayPort LED Monitor
Quicklinx: BJ4LWS00 Mfr#: 210-AEUR
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
£77.52 ex VAT
£93.02 inc VAT
The Dell 17 monitor E1715S is your smart choice for reliability and essential features that can help drive productivity. Add the E1715S to your workplace for a great viewing experience in just about any setting.
  • Essential features
    The E1715S offers HD quality viewing, easy connectivity and compatibility with legacy custom applications.
  • Responsible design
    The E1715S minimizes power consumption with an efficient LED backlight and PowerNap technology.
  • A great fit
    This compact, 5:4 aspect ratio monitor can fit into smaller spaces while still maintaining compatibility with software requiring a 5:4 display ratio.
  • Simple connections
    Simplify connections to laptop and desktop PCs with VGA and DisplayPort connectors.
  • Tilt adjustment
    Tilt the screen up to 5.5° forward or 22° backward for optimal viewing comfort.
Dell E1715S - LED monitor - 17"
LED-backlit LCD monitor - 17"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/344935
Energy Class
Class D
Power Consumption (On mode)
9 W
Panel Type
TN
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 85% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
37.45 cm x 16.55 cm x 38.95 cm
Environmental Standards
TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
335 kg carbon emissions
Plug and Play, VESA EDID, DDC/CI, RoHS, CECP
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class D
Diagonal Size
17"
Panel Type
TN
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue
OSD Languages
Chinese (simplified), English, German, French, Portuguese, Russian, Spanish, Japanese
LED edgelight system, PowerNap, Image Enhance
37.45 cm x 16.55 cm x 38.95 cm - with stand
VGA , DisplayPort
Mechanical
Tilt
Tilt Angle
-5.5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support
Stand, VESA screw cover
1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
9 W
9 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption (Max)
14 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 37.45 cm - depth: 16.55 cm - height: 38.95 cm , Without stand - width: 37.45 cm - depth: 4.65 cm - height: 30.69 cm - weight: 2.08 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
66
Manufacturing (kg CO2e)
302
Logistics (kg CO2e)
27
Use (kg CO2e)
124
EOL (kg CO2e)
2
Total Carbon w/o Use Phase (kg CO2e)
330
PAIA Version
9/5/2018
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
Accessories (3)
BJ4L StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
BJ4L StarTech.com Dual Monitor Stand In Stock £82.12
BJ4L StarTech.com TV/Monitor Arm - Wallmount In Stock £84.28
Other bundles (2)
BJ4L C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.43
BJ4L C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £14.85
Diagonal Size: 17in
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: Dell
