The Dell 17 monitor E1715S is your smart choice for reliability and essential features that can help drive productivity. Add the E1715S to your workplace for a great viewing experience in just about any setting.
Essential features
The E1715S offers HD quality viewing, easy connectivity and compatibility with legacy custom applications. -
Responsible design
The E1715S minimizes power consumption with an efficient LED backlight and PowerNap technology. -
A great fit
This compact, 5:4 aspect ratio monitor can fit into smaller spaces while still maintaining compatibility with software requiring a 5:4 display ratio. -
Simple connections
Simplify connections to laptop and desktop PCs with VGA and DisplayPort connectors. -
Tilt adjustment
Tilt the screen up to 5.5° forward or 22° backward for optimal viewing comfort.
- Dell E1715S - E Series - LED monitor - 17"
- LED-backlit LCD monitor - 17"
- Energy Class
- Class D
- Power Consumption (On mode)
- 9 W
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 85% (CIE 1976)
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 37.45 cm x 16.55 cm x 38.95 cm
- Localisation
- United Kingdom
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- CEL
- 3-year warranty
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 17"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 85% (CIE 1976)
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 81 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- PowerNap
- Black
- 37.45 cm x 16.55 cm x 38.95 cm - with stand
- VGA , DisplayPort
Mechanical
- Tilt
- Tilt Angle
- -5.5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- CEL
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 9 W
- Power Consumption SDR (On mode)
- 9 kWh/1000h
- Power Consumption (Typical)
- 11 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 37.45 cm - depth: 16.55 cm - height: 38.95 cm , Without stand - width: 37.45 cm - depth: 4.65 cm - height: 30.69 cm - weight: 2.08 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - advance parts replacement - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
