Maximize your workspace with the Dell E-Port II Replicator. This E-Port Replicator gives you a comfortable work space where you can plug a keyboard, mouse and monitor to the port replicators and use your laptop like a desktop! Simplified connectivity facilitates a single interface to connect to your printer, monitor or other peripheral devices.
- Dell E-Port II Simple - port replicator
- Product Type
- Port replicator
- 20 cm x 17 cm x 5.37 cm
- 780 g
- Localisation
- United Kingdom, Ireland
- Power
- Power adapter - external 240 Watt Power Provided
- Designed For
- Precision 3510, 7510, 7710, M2800, M4600, M4700, M4800, M6600, M6700, M6800
- Product Type
- Port replicator
- 20 cm
- 17 cm
- 5.37 cm
- 780 g
- Localisation
- 1 x microphone - input - mini-phone 3.5 mm , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 3 x USB 2.0 - 4 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - Ethernet - RJ-45 , 1 x headphones - output - mini-phone 3.5 mm , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - DisplayPort - 20 pin DisplayPort
- Power Device
- Power Provided
- 240 Watt
- Designed For
- Dell Precision 3510, 7510, 7710, M2800, M4600, M4700, M4800, M6600, M6700, M6800
