Dell E-Port II Simple Port Replicator
Quicklinx: B3LRWS00 Mfr#: 452-11520
Maximize your workspace with the Dell E-Port II Replicator. This E-Port Replicator gives you a comfortable work space where you can plug a keyboard, mouse and monitor to the port replicators and use your laptop like a desktop! Simplified connectivity facilitates a single interface to connect to your printer, monitor or other peripheral devices.
Dell E-Port II Simple - port replicator
Port replicator
20 cm x 17 cm x 5.37 cm
780 g
United Kingdom, Ireland
Power adapter - external 240 Watt Power Provided
Precision 3510, 7510, 7710, M2800, M4600, M4700, M4800, M6600, M6700, M6800
Port replicator
20 cm
17 cm
5.37 cm
780 g
1 x microphone - input - mini-phone 3.5 mm , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 3 x USB 2.0 - 4 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - Ethernet - RJ-45 , 1 x headphones - output - mini-phone 3.5 mm , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - DisplayPort - 20 pin DisplayPort
Power Provided
240 Watt
Dell Precision 3510, 7510, 7710, M2800, M4600, M4700, M4800, M6600, M6700, M6800
B3LR C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
