Space saving, the Dell Dual Monitor Stand - MDS19 mounts up to two 27-inch monitors, providing the screen real estate you need to be most productive. The dual monitor stand frees up the workspace in front of you for writing and referencing. The round cable management slot neatly channels cables within its stand, routing them along the curved bar with cable clips keeping the cables intact and hidden from view. Each monitor panel is fully adjustable, allowing you to set the height, tilt, pivot, and swivel to suit your viewing comfort. The stand's tool-free installation feature makes it easy to securely snap Dell UltraSharp and P-series monitors with Quick Release into place without the need for screws. It also supports Dell E-series monitors and other 19" to 27" 100 mm x 100 mm standard VESA compatible monitors.
- Dell MDS19 Dual Monitor Stand stand - for 2 monitors
- Product Type
- Stand
- 57.7 cm x 24.9 cm
- Tilt
- -5° to 24°
- Lift
- 13 cm
- Rotation
- -90° to 90°
- Swivel
- -10° to 15°
- Adjustments
- Tilt, swivel, rotation, lift
- Recommended Use
- 2 monitors
- Recommended Display Size
- 19"-27"
- VESA Mounting Interface
- Max Mounting Pattern Size
- 100 x 100 mm
- Max Load Weight
- 6 kg
- Package Content
- Cable clips, round cable slot
- 3-year warranty
- 57.7 cm
- 24.9 cm
- Package Content
AV Furniture
- Stand
- Recommended Use
- 2 monitors
- 100 x 100 mm
- Cable Management
- Cable clips on the bar, round cable slot
- 19"-27"
- Tilt
- -5° to 24°
- Lift
- 13 cm
- Rotation
- -90° to 90°
- Swivel
- -10° to 15°
- Adjustments
- Max Load Weight
- 6 kg
- Min Load Weight
- 2.2 kg
- Limited warranty - 3 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H25C 050920 Condition: Customer return - item has been used but is in excellent condition |
£101.11 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
