Dell Dual Monitor Stand - MDS19
Quicklinx: H25CWS00 Mfr#: DELL-MDS19
Accessory Type: Stand
More than 50 In Stock
£166.38 ex VAT
£199.65 inc VAT
Space saving, the Dell Dual Monitor Stand - MDS19 mounts up to two 27-inch monitors, providing the screen real estate you need to be most productive. The dual monitor stand frees up the workspace in front of you for writing and referencing. The round cable management slot neatly channels cables within its stand, routing them along the curved bar with cable clips keeping the cables intact and hidden from view. Each monitor panel is fully adjustable, allowing you to set the height, tilt, pivot, and swivel to suit your viewing comfort. The stand's tool-free installation feature makes it easy to securely snap Dell UltraSharp and P-series monitors with Quick Release into place without the need for screws. It also supports Dell E-series monitors and other 19" to 27" 100 mm x 100 mm standard VESA compatible monitors.
Dell MDS19 Dual Monitor Stand stand - for 2 monitors
Stand
57.7 cm x 24.9 cm
Tilt
-5° to 24°
Lift
13 cm
Rotation
-90° to 90°
Swivel
-10° to 15°
Adjustments
Tilt, swivel, rotation, lift
Recommended Use
2 monitors
Recommended Display Size
19"-27"
VESA Mounting Interface
Max Mounting Pattern Size
100 x 100 mm
Max Load Weight
6 kg
Package Content
Cable clips, round cable slot
3-year warranty
57.7 cm
24.9 cm
Package Content
AV Furniture
Stand
Recommended Use
2 monitors
100 x 100 mm
Cable Management
Cable clips on the bar, round cable slot
19"-27"
Tilt
-5° to 24°
Lift
13 cm
Rotation
-90° to 90°
Swivel
-10° to 15°
Adjustments
Max Load Weight
6 kg
Min Load Weight
2.2 kg
Limited warranty - 3 years
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: H25C 050920
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £51.34
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Dell
Stock Status: Used Stock
