Dell Dual Monitor Stand - MDS19
Quicklinx: H25CWS00 Mfr#: DELL-MDS19
16 In Stock
£149.14 ex VAT
£178.96 inc VAT
Space saving, the Dell Dual Monitor Stand - MDS19 mounts up to two 27-inch monitors, providing the screen real estate you need to be most productive. The dual monitor stand frees up the workspace in front of you for writing and referencing. The round cable management slot neatly channels cables within its stand, routing them along the curved bar with cable clips keeping the cables intact and hidden from view. Each monitor panel is fully adjustable, allowing you to set the height, tilt, pivot, and swivel to suit your viewing comfort. The stand's tool-free installation feature makes it easy to securely snap Dell UltraSharp and P-series monitors with Quick Release into place without the need for screws. It also supports Dell E-series monitors and other 19" to 27" 100 mm x 100 mm standard VESA compatible monitors.
Dell MDS19 Dual Monitor Stand stand - for 2 monitors
Stand
57.7 cm x 24.9 cm
Tilt
-5° to 24°
Lift
13 cm
Rotation
-90° to 90°
Swivel
-10° to 15°
Adjustments
Tilt, swivel, rotation, lift
Recommended Use
2 monitors
Recommended Display Size
19"-27"
VESA Mounting Interface
Max Mounting Pattern Size
100 x 100 mm
Max Load Weight
6 kg
Package Content
Cable clips, round cable slot
3-year warranty
57.7 cm
24.9 cm
Package Content
AV Furniture
Stand
Recommended Use
2 monitors
100 x 100 mm
Cable Management
Cable clips on the bar, round cable slot
19"-27"
Tilt
-5° to 24°
Lift
13 cm
Rotation
-90° to 90°
Swivel
-10° to 15°
Adjustments
Max Load Weight
6 kg
Min Load Weight
2.2 kg
Limited warranty - 3 years
