Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE
Quicklinx: GDTTWS00 Mfr#: DELL-WD19S180W
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black
£144.84 ex VAT
£173.80 inc VAT
Boost your PC's power on the first modular USB-C dock with a future-ready design.
  • Unmatched charging
    Increase your power delivery by up to 30% more than standard USB-C on the fast-charging dock, delivering 130 W of power with the 180 W adapter.
  • Mix and match
    Evolve as your needs change with this versatile dock. The future-ready design lets you swap out modules with ease if you need to do field replacements or upgrade your systems.
  • Ultimate connectivity
    USB-C connectivity makes it easier than ever to deliver power, data, audio, and video in one convenient cable, no matter what system you use. Plus, with support for up to three QHD or dual 4K monitors, you can connect to everything you need.
  • Clean and clutter-free
    Stay productive by mounting your dock behind your monitor or under your desk with the optional, secure VESA mount, that offers complete flexibility with the built-in one-meter cable.
  • Information in a flash
    With data transfer speeds of up to 10Gbps, you can stay productive when connected to all your devices.
Dell WD19S - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, 2 x DP, USB-C
20.5 cm x 9 cm x 2.9 cm
585 g
Gigabit Ethernet
Power adapter AC 120/230 V (50/60 Hz) 180 Watt Power Provided
Carbon Footprint
35.74 kg carbon emissions
3-year warranty
Docking station
20.5 cm
9 cm
2.9 cm
585 g
Enclosure Colour
Video
Max Resolution Details
5120 x 2880 - 60 Hz
2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C , 3 x USB 3.1 Gen 1 - 9 pin USB Type A , 2 x USB-C 3.1 Gen 2 , 1 x network - Ethernet 1000 - RJ-45
1 x USB-C cable - 80 cm
Security lock slot (cable lock sold separately), 130W power delivery to Dell systems, 90W power delivery to non-Dell systems, wireless vPro
Security Slot Type
Noble Wedge security slot / Kensington security slot
Power adapter
Power Provided
180 Watt
Red Hat Enterprise Linux, Windows 10, Ubuntu 18.04
Limited warranty - 3 years
Carbon Footprint
Manufacturing (kg CO2e)
25.6
Logistics (kg CO2e)
6.61
Use (kg CO2e)
5.95
EOL (kg CO2e)
-2.42
Total Carbon w/o Use Phase (kg CO2e)
29.79
Device Type: Laptop
Colour: Black
Brand: Dell
