The Dell Dock-130W provides a common docking experience for both Dell and non-Dell platforms via Display Port over USB Type-CM, ensuring a reliable connection and crisp display. The dock connects with a single cable, freeing up space on your desk and in your workspace with the added ability to mount behind a monitor or on your desk. Great for presentations, the small and compact Dell Dock enables fast, efficient connectivity to multiple displays and all your everyday peripherals through one convenient cable.
Single cable connectivity
Featuring a powerful DisplayPort over USB Type-C cable, with the Dell Dock-130W you can quickly connect your laptop or tablet to a single data and power source. You'll also enjoy an easy, reliable connection from your laptop or tablet to dual FHD displays or a single 2560 x 1600 display, and all your essential peripherals. It also supports maximum display resolution of 4K at 30 Hz. -
Small footprint and big flexibility
The Dell Dock-130W is small in size - just 6.1 x 4.3 x. 83 inches (155 x 109 x 21 mm) - and has one single cable. Place it anywhere you want to work - in your traditional office workspace, a hot desk or a conference room - even if space is limited. -
One dock for all
The Dell Dock-130W is compatible with select Dell laptops, workstations, tablets and many compatible non-Dell devices with USB-Type C connectivity. Easily connect to displays, a mouse, keyboard and audio devices through the Dell Dock-130W from your compatible system of choice. -
Connect for collaboration
Grab your laptop and head to the next meeting where you, and your co-workers, will be able to quickly connect to the Dell Dock-130W and share your latest PowerPoint presentation through a connected display screen or projector. -
Enhanced video performance
USB Type-C connectivity is the latest and extremely reliable technology for video performance. Your display will be crisp and clear.
- Dell Dock WD15 - docking station - USB-C - VGA, HDMI, Mini DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- 15.5 cm x 10.9 cm x 2.11 cm
- 422 g
- Localisation
- United Kingdom
- Networking
- Gigabit Ethernet
- Power
- Power adapter 130 Watt Power Provided
- Designed For
- Alienware 13 R2; Latitude 5175 2-in-1, 5179, 5280, 5480, 5580, 7275, 7280, 7370, 7480; Venue 10 Pro (5056), 8 Pro (5855); XPS 12 9250, 13 9350, 15 9550 (130 Watt)
- Product Type
- Docking station
- 15.5 cm
- 10.9 cm
- 2.11 cm
- 422 g
- Localisation
- United Kingdom
- Data Link Protocol
- Gigabit Ethernet
- 2 x USB 2.0 - 4 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - Mini DisplayPort - Mini DisplayPort , 1 x network - Ethernet 1000 - RJ-45 , 1 x headset - output - mini-phone 3.5 mm , 1 x audio - output - mini-phone 3.5 mm , 1 x video - VGA - 15 pin D-Sub (DB-15)
- Cables Included
- 1 x DisplayPort / USB-C cable - 80 cm , 1 x SuperSpeed USB-C cable - 80 cm
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- Power Provided
- 130 Watt
- OS Required
- Red Hat Linux 7.2, Microsoft Windows 7 / 8 / 8.1 / 10
- Designed For
- Alienware 13 R2 , Dell Latitude 5175 2-in-1, 5179, 5280, 5480, 5580, 7275, 7280, 7370, 7480 , Dell Venue 10 Pro (5056), 8 Pro (5855) , Dell XPS 12 9250, 13 9350, 15 9550 (130 Watt)
