Dell Dock WD19 Docking Station - HDMI, DisplayPort, USB-C
Quicklinx: FDWVWS00 Mfr#: DELL-WD19-130W
Boost your PC's power on this powerful and modular dock, with a future-ready design.
  • Smooth and seamless
    Work without disruptions utilizing a single firmware on this manageable dock.
  • Mix and match
    Evolve as your needs change with this versatile dock. The future-ready design lets you swap out modules with ease if you need to do field replacements or upgrade your systems.
  • Ultimate connectivity
    USB-C connectivity makes it easier than ever to deliver power, data, audio and video in one convenient cable, no matter what system you use.
Dell Dock WD19 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, 2 x DP, USB-C
20.5 cm x 9 cm x 2.8 cm
585 g
Gigabit Ethernet
Power adapter AC 120/230 V (50/60 Hz) 130 Watt Power Provided
3-year warranty
Dell Latitude 3390 2-in-1, 3400, 3490, 3500, 3590, 5280, 5285 2-in-1, 5289, 5290, 5290 2-in-1, 5300, 5300 2-in-1, 5400, 5420, 5424 Rugged, 5480, 5490, 5500, 5580, 5590, 7200 2-in-1, 7280, 7285, 7290, 7300, 7380, 7389, 7390, 7390 2-in-1, 7400, 7400 2-in-1, 7480, 7490; XPS 9360, 9365, 9370, 9380
Docking station
20.5 cm
9 cm
2.8 cm
585 g
Enclosure Colour
Video
Max Resolution Details
3840 x 2160 - 30 Hz
2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C , 3 x USB 3.1 Gen 1 - 9 pin USB Type A , 2 x USB-C 3.1 Gen 2 , 1 x speakers - output - mini-phone 3.5 mm , 1 x headset - output - mini-phone 3.5 mm , 1 x network - Ethernet 1000 - RJ-45
1 x SuperSpeed USB-C cable - 1 m
Security lock slot (cable lock sold separately), 90W power delivery
Security Slot Type
Noble Wedge security slot / Kensington security slot
Power adapter
Power Provided
130 Watt
Red Hat Enterprise Linux, Windows 10, Ubuntu 18.04
Limited warranty - 3 years
Dell Latitude 3390 2-in-1, 3400, 3490, 3500, 3590, 5280, 5285 2-in-1, 5289 2-In-1, 5290, 5290 2-in-1, 5300, 5300 2-in-1, 5400, 5420 Rugged, 5424 Rugged, 5480, 5490, 5500, 5580, 5590, 7200 2-in-1, 7280, 7285 2-in-1, 7290, 7300, 7380, 7389 2-in-1, 7390, 7390 2-in-1, 7400, 7400 2-in-1, 7480, 7490 , Dell Vostro 5390, 5391 , Dell XPS 13 9360, 13 9365 2-in-1, 13 9370, 13 9380
