Dell UltraSharp U4924DW 49" 5120x1440 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor
Quicklinx: JGTXWS00 Mfr#: DELL-U4924DW
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: USB-C, DisplayPort, HDMI
13 In Stock
£996.32 ex VAT
£1,195.58 inc VAT
Dell UltraSharp 49 Curved Monitor - U4924DW 124.5cm (49),3Y Base Adv Ex.
Dell UltraSharp U4924DW - LED monitor - curved - 49"
LED-backlit LCD monitor - 49"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1367150
Energy Class
Class G
Power Consumption (On mode)
45 W
Curved Screen
USB-C hub
Panel Type
IPS Black
Aspect Ratio
32:9
Native Resolution
5K Dual QHD 5120 x 1440 at 60 Hz
Pixel Pitch
0.2324 mm
Brightness
350 cd/m²
Contrast Ratio
2000:1 / 2000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3, 98% P3
Input Connectors
2xHDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
121 cm x 26.9 cm x 40.1 cm
16.3 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
1140 kg carbon emissions
RoHS, BFR-free, PVC-free
3-year warranty
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class G
Diagonal Size
49"
Curved Screen
Yes (3800R)
Built-in Devices
USB-C hub
Panel Type
IPS Black
Aspect Ratio
32:9
Native Resolution
Pixel Pitch
0.2324 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED edgelight backlight
Mercury free, arsenic-free glass, Dell Easy Arrange, Delta E<2 calibration, 3-sided bezeless
121 cm x 26.9 cm x 40.1 cm - with stand (lowest position)
16.3 kg
Audio
Speakers - stereo
Output Power / Channel
9 watt
2 x HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , USB-C/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W) , USB-C 3.2 Gen 2 upstream , 4 x USB 3.2 Gen 2 downstream , 2 x USB-C 3.2 Gen 2 downstream (power up to 15W) , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out , Network
Mechanical
Tilt Angle
-5/+21
Swivel Angle
340
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm, 200 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
USB-C to USB-C cable - 1 m , DisplayPort cable - 1.83 m , USB-C to USB-A cable - 1 m , HDMI cable - 1.83 m
Security Slot Type
Kensington security slot
Input Voltage
45 W
45 kWh/1000h
Power Consumption (Typical)
290 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
On / Off Switch
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 121 cm - depth: 26.9 cm - height: 40.1 cm - weight: 16.3 kg , With stand (highest position) - width: 121 cm - depth: 26.9 cm - height: 52.1 cm - weight: 16.3 kg , Without stand - width: 121 cm - depth: 11.2 cm - height: 36.6 cm - weight: 12.2 kg
Shipping Weight
27.7 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
318
Manufacturing (kg CO2e)
535.8
Logistics (kg CO2e)
135.66
Use (kg CO2e)
452.58
EOL (kg CO2e)
15.96
Total Carbon w/o Use Phase (kg CO2e)
685
PAIA Version
1.3.1, 2022
Premium Panel Exchange
Bundled Services
10 - 80% (non-condensing)
JGTX Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £26.32
JGTX Dell SB521A Magnetic Sound bar In Stock £28.80
JGTX Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £59.98
Diagonal Size: 49in
Response Time: 5ms
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Dell
Price Range Ex VAT: £750 - £1000
