- Dell UltraSharp U4924DW - LED monitor - curved - 49"
- LED-backlit LCD monitor - 49"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1367150
- Energy Class
- Class G
- Power Consumption (On mode)
- 45 W
- Curved Screen
- USB-C hub
- Panel Type
- IPS Black
- Aspect Ratio
- 32:9
- Native Resolution
- 5K Dual QHD 5120 x 1440 at 60 Hz
- Pixel Pitch
- 0.2324 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 2000:1 / 2000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% Rec 709, 100% sRGB, 98% DCI-P3, 98% P3
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 121 cm x 26.9 cm x 40.1 cm
- 16.3 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 1140 kg carbon emissions
- RoHS, BFR-free, PVC-free
- 3-year warranty
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 49"
- Curved Screen
- Yes (3800R)
- Built-in Devices
- USB-C hub
- Panel Type
- IPS Black
- Aspect Ratio
- 32:9
- Native Resolution
- Pixel Pitch
- 0.2324 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED edgelight backlight
- Mercury free, arsenic-free glass, Dell Easy Arrange, Delta E<2 calibration, 3-sided bezeless
- 121 cm x 26.9 cm x 40.1 cm - with stand (lowest position)
- 16.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 9 watt
- 2 x HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , USB-C/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W) , USB-C 3.2 Gen 2 upstream , 4 x USB 3.2 Gen 2 downstream , 2 x USB-C 3.2 Gen 2 downstream (power up to 15W) , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out , Network
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 340
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- USB-C to USB-C cable - 1 m , DisplayPort cable - 1.83 m , USB-C to USB-A cable - 1 m , HDMI cable - 1.83 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 45 W
- Power Consumption SDR (On mode)
- 45 kWh/1000h
- Power Consumption (Typical)
- 290 watt
- Power Consumption Stand by
- 0.3 watt
- 0.3 watt
- On / Off Switch
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 121 cm - depth: 26.9 cm - height: 40.1 cm - weight: 16.3 kg , With stand (highest position) - width: 121 cm - depth: 26.9 cm - height: 52.1 cm - weight: 16.3 kg , Without stand - width: 121 cm - depth: 11.2 cm - height: 36.6 cm - weight: 12.2 kg
- Shipping Weight
- 27.7 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 318
- Manufacturing (kg CO2e)
- 535.8
- Logistics (kg CO2e)
- 135.66
- Use (kg CO2e)
- 452.58
- EOL (kg CO2e)
- 15.96
- Total Carbon w/o Use Phase (kg CO2e)
- 685
- PAIA Version
- 1.3.1, 2022
- Premium Panel Exchange
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £26.32 |
Dell SB521A Magnetic Sound bar | In Stock | £28.80 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £62.54 |
