Experience rich, clear sound with this intelligent Microsoft Teams-certified speakerphone.
Less interruptions
Your voice remains clear in meetings, with AI Noise Cancellation filtering out all background noise in your environment. -
Great audio quality
True Stereo Output, with left and right speakers and wide-band audio frequency range, gives you distortion-free, rich audio, when whether you're hard at work or listening to music. -
Real-time collaboration
Full Duplex Audio allows multiple participants to speak simultaneously, and echo-cancellation eliminates interruptions. -
Quickly join meetings
Easily navigate through your work with the ability to quickly access meetings and notifications using a dedicated MS Teams button on the world's most intelligent Microsoft Teams-certified speakerphone. -
Multiple connectivity options
Connect the speakerphone to monitors, laptops, or desktops through the USB-A or USB-C ports. -
Elegant look
Complement your Dell display with the speakerphone's matching design and finish.
- Dell AI Noise Cancellation Speakerphone SP3022 - VoIP desktop speakerphone - USB-A, USB-C
- Product Type
- VoIP desktop speakerphone - wired - USB-A, USB-C
- Compatibility
- Windows
- Connectivity Technology
- Wired
- Audio Specifications
- Frequency Response 90 - 20000 Hz
- Active Noise Canceling
- Microphone Operation Mode
- Omni-directional
- Controls
- Answer call, answer/end, microphone on/mute switch, microphone volume, Microsoft Teams button, reject call, volume, power/streaming LED indicator
- Compatible Software
- Skype for Business, Cisco WebEx, FaceTime, Google Hangouts, GoToMeetings, Microsoft Teams, Zoom
- 3-year warranty
- Product Type
- Compatibility
- Windows
- 7.1 cm
- 22.6 cm
- 5.87 cm
Audio Output
- Wired
- Active Noise Cancelling Technology
- Artificial Intelligence Noise Cancellation
- 90 - 20000 Hz
Microphone
- Omni-directional
- Signal-to-Noise Ratio
- 72 dB
Remote Control
- Controls
- Cable Details
- USB-A to USB-C adapter
- Supported Host Device OS
- Windows 10 (64-bit), Windows 11 (64-bit)
- Limited warranty - 3 years
