Dell Dell Speakerphone SP3022
Quicklinx: HHBNWS00 Mfr#: SP3022-DEMEA
22 In Stock
£50.75 ex VAT
£60.90 inc VAT
Experience rich, clear sound with this intelligent Microsoft Teams-certified speakerphone.
  • Less interruptions
    Your voice remains clear in meetings, with AI Noise Cancellation filtering out all background noise in your environment.
  • Great audio quality
    True Stereo Output, with left and right speakers and wide-band audio frequency range, gives you distortion-free, rich audio, when whether you're hard at work or listening to music.
  • Real-time collaboration
    Full Duplex Audio allows multiple participants to speak simultaneously, and echo-cancellation eliminates interruptions.
  • Quickly join meetings
    Easily navigate through your work with the ability to quickly access meetings and notifications using a dedicated MS Teams button on the world's most intelligent Microsoft Teams-certified speakerphone.
  • Multiple connectivity options
    Connect the speakerphone to monitors, laptops, or desktops through the USB-A or USB-C ports.
  • Elegant look
    Complement your Dell display with the speakerphone's matching design and finish.
Dell AI Noise Cancellation Speakerphone SP3022 - VoIP desktop speakerphone
VoIP desktop speakerphone - wired - USB-A, USB-C
Compatibility
Windows
Wired
Audio Specifications
Frequency Response 90 - 20000 Hz
Active Noise Canceling
Microphone Operation Mode
Omni-directional
Controls
Answer call, answer/end, microphone on/mute switch, microphone volume, Microsoft Teams button, reject call, volume, power/streaming LED indicator
Compatible Software
Skype for Business, Cisco WebEx, FaceTime, Google Hangouts, GoToMeetings, Microsoft Teams, Zoom
3-year warranty
Compatibility
Windows
7.1 cm
22.6 cm
5.87 cm
Audio Output
Wired
Active Noise Cancelling Technology
Artificial Intelligence Noise Cancellation
Frequency Response
90 - 20000 Hz
Microphone
Omni-directional
Signal-to-Noise Ratio
72 dB
Remote Control
Controls
Cable Details
USB-A to USB-C adapter
Supported Host Device OS
Windows 10 (64-bit), Windows 11 (64-bit)
Compatible Software
Limited warranty - 3 years
Brand: Dell
