Dell Dell Pro Wireless Mouse MS5120W Black
Quicklinx: HND2WS00 Mfr#: MS5120W-BLK
More than 50 In Stock
£25.05 ex VAT
£30.06 inc VAT
Connect your mouse conveniently via Wi-Fi or Bluetooth with any PC and enhance your productivity with programmable shortcut buttons and a long battery life.
  • Connect seamlessly
    The dual-mode connectivity incorporates a 2.4 GHz wireless and a Bluetooth 5.0 connection so you can pair and connect to almost any PC via your preferred mode.
  • Easy pairing
    Pair your mouse to your Windows laptop via Bluetooth instantly using Microsoft Swift Pair, so you do not need to configure in Windows settings every time.
  • Built to last
    Work for up to 36 months on a single battery, so you can forget about having to recharge daily, weekly or even monthly. This lets you get on with your tasks smoothly without having to be concerned with battery replacements.
  • Precise tracking
    A 1600 dpi sensor ensures this Dell wireless mouse handles high-resolution screens easily. Its optical sensor offers accurate tracking and is ideal on most desk surfaces.
  • Quick access
    Intuitively positioned shortcut buttons allow easy navigation across web pages and applications. Browse back and forth efficiently between pages onscreen effortlessly.
Dell MS5120W - mouse - 2.4 GHz, Bluetooth 5.0 - black
Mouse
Wireless - 2.4 GHz, Bluetooth 5.0
Bundled Services
3 years NBD Advance Exchange
6.15 cm x 10.45 cm x 3.83 cm
73.7 g
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
1600 dpi
Swift Pair
AA type
Linux, Android, Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10
Mouse
Bundled Services
6.15 cm
10.45 cm
3.83 cm
73.7 g
Input Device
Wireless
Optical
Buttons Qty
7
Movement Resolution
1600 dpi
Swift Pair
1 AA battery
AA type
Run Time (Up To)
36 months
