The Dell Pro Micro Plus QBM1250 is designed to provide a compact yet powerful computing solution. With a 512 GB SSD and an Intel Core Ultra 5 processor featuring up to 5 GHz turbo speed, this personal computer can handle demanding tasks seamlessly. The ultra small form factor chassis allows for easy integration into any workspace while maintaining optimal performance and connectivity options. Operating at temperatures between 10°C and 35°C and featuring a range of ports, including USB 3.2 Gen 2 and DisplayPort, this system accommodates various peripheral setups to enhance productivity. Furthermore, the machine includes advanced security features, such as a Trusted Platform Module (TPM 2.0) and a padlock loop, ensuring data protection. EPEAT Gold and ENERGY STAR certifications illustrate its commitment to sustainability, making it a responsible choice for environmentally conscious users. The integrated Realtek ALC3204 audio codec completes the package, allowing for clear sound output in a compact design ideal for business and personal use.
- Dell Pro Micro Plus QBM1250 - micro - AI PC - Core Ultra 5 235 3.4 GHz - 16 GB - SSD 512 GB
- Personal computer - micro - AI PC
- Bundled Services
- 3 Years Basic Onsite Service after Remote Diagnosis with Hardware-Only Support
- Processor
- Intel Core Ultra 5 (Series 2) 235 / 3.4 GHz (up to 5 GHz, (14-core)
- Processor Main Features
- 14 Threads, 65W CPU
- Neural Processor Unit (NPU)
- Intel AI Boost - up to 13 TOPS
- Cache Memory
- 24 MB
- Cache Per Processor
- 24 MB
- RAM
- 16 GB (installed) / 64 GB (max) - DDR5 SDRAM - non-ECC
- Hard Drive
- SSD 512 GB - PCI Express 4.0 - M.2 - NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel Graphics Shared Video Memory (UMA) - up to 6 TOPS
- Networking
- 1GbE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5, Wi-Fi 6E
- Power
- (50/60 Hz)
- OS Provided
- Windows 11 Pro
- Software Included
- Activate your Microsoft 365 for a 30 day trial
- Black
- 3.6 cm x 17.8 cm x 18.2 cm
- 1.22 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 80.7 kg carbon emissions
- Personal computer
- AI Level
- AI PC
- Bundled Services
- Product Form Factor
- Micro
- Built-in Devices
- Internal aerial
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz (P-core) / 2.9 GHz (E-core)
- Max Turbo Speed
- 5 GHz (P-core) / 4.4 GHz (E-core)
- Number of Cores
- 14-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel Q870
- Intel AI Boost
- NPU Performance Up To (TOPS)
- 13 TOPS
- Total Processor Performance Up To (TOPS)
- 27 TOPS
- AI Datatype Support on NPU
- INT8
- Sparsity Support
- AI Software Frameworks Supported by NPU
- DirectML, OpenVINO, WebNN, WindowsML, ONNX RT
- Windows Studio Effects Support
Cache Memory
- Installed Size
- 24 MB
- 24 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 5600 MT/s
- Rated Memory Speed
- 5600 MT/s
- Form Factor
- SO-DIMM 262-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 512 GB
- Interface Type
- PCI Express 4.0
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
- Keyboard Name
- Dell KM5221W Pro Wireless Keyboard and Mouse Combo
- Interface (Bus) Type
- M.2 2230
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wi-Fi 6E AX 211
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6E)
- Dual stream (2x2)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax
- Slots
- 2 (total) / 1 (free) x M.2 Card - 2230/2280 (for SSD) , 1 (total) / 0 (free) x M.2 Card - 2230 (for wireless module)
- 1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.2 Gen 2x2 , 1 x USB-C 3.2 Gen 2 , 4 x USB 3.2 Gen 2 (one of them with PowerShare) , 2 x USB 3.2 Gen 1 (one of them supports SmartPower On) , 1 x headphones/microphone , 3 x DisplayPort 1.4a
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power adapter
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Power Provided
- 180 watt
Operating System / Software
- OS Provided
- Windows 11 Pro
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 45.0306
- Logistics (kg CO2e)
- 2.2596
- Use (kg CO2e)
- 32.8449
- EOL (kg CO2e)
- 0.5649
- Total Carbon w/o Use Phase (kg CO2e)
- 47.8551
- PAIA Version
- GaBi version 1, 2024
- 3.6 cm
- 17.8 cm
- 18.2 cm
- 1.22 kg
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
Monitors (12)
Dell UltraSharp 24" 1920 x 1080 5 ms IPS | In Stock | £157.91 |
Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor | In Stock | £341.58 |
Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor | In Stock | £88.69 |
Dell UltraSharp U2724D - LED monitor - QHD - 27" | In Stock | £278.61 |
Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £139.87 |
Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £119.24 |
Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £135.97 |
Dell Pro E2425HM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £79.21 |
Dell P2424HT 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £275.51 |
Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £259.41 |
Dell Pro Plus P2425D 24" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £169.40 |
Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £87.77 |
Accessories (1)
Dell OptiPlex Micro and Thin Client VESA Mount w/Adapter Bracket | In Stock | £24.78 |
Keyboards and Mice (4)
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £44.32 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £43.18 |
Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot | In Stock | £48.55 |
Dell Dell Mobile Wireless Mouse - MS3320W - Black | In Stock | £15.38 |
Other bundles (4)
Dell Slim DW316 USB External DVD Drive | In Stock | £40.60 |
Dell SB521A Magnetic Sound bar | In Stock | £30.78 |
Dell WEBCAM - WB3023 | In Stock | £47.02 |
Dell Dell Speakerphone SP3022 | In Stock | £67.46 |
