Dell Dell Pro Micro Plus QBM1250 - Micro Core Ultra 5 235 / up to
Quicklinx: JFKCWS00 Mfr#: D6GXR
Processor Type: Core Ultra 5
Operating System: Windows 11 Pro
Hard Drive Capacity: 512GB
Storage Type: SSD
Processor Model: 235
  • IEEE 802.11n
More than 50 In Stock
£996.77 ex VAT
£1,196.12 inc VAT
The Dell Pro Micro Plus QBM1250 is designed to provide a compact yet powerful computing solution. With a 512 GB SSD and an Intel Core Ultra 5 processor featuring up to 5 GHz turbo speed, this personal computer can handle demanding tasks seamlessly. The ultra small form factor chassis allows for easy integration into any workspace while maintaining optimal performance and connectivity options. Operating at temperatures between 10°C and 35°C and featuring a range of ports, including USB 3.2 Gen 2 and DisplayPort, this system accommodates various peripheral setups to enhance productivity. Furthermore, the machine includes advanced security features, such as a Trusted Platform Module (TPM 2.0) and a padlock loop, ensuring data protection. EPEAT Gold and ENERGY STAR certifications illustrate its commitment to sustainability, making it a responsible choice for environmentally conscious users. The integrated Realtek ALC3204 audio codec completes the package, allowing for clear sound output in a compact design ideal for business and personal use.
Dell Pro Micro Plus QBM1250 - micro - AI PC - Core Ultra 5 235 3.4 GHz - 16 GB - SSD 512 GB
Personal computer - micro - AI PC
Bundled Services
3 Years Basic Onsite Service after Remote Diagnosis with Hardware-Only Support
Intel Core Ultra 5 (Series 2) 235 / 3.4 GHz (up to 5 GHz, (14-core)
Processor Main Features
14 Threads, 65W CPU
Neural Processor Unit (NPU)
Intel AI Boost - up to 13 TOPS
Cache Memory
24 MB
Cache Per Processor
24 MB
RAM
16 GB (installed) / 64 GB (max) - DDR5 SDRAM - non-ECC
Hard Drive
SSD 512 GB - PCI Express 4.0 - M.2 - NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
No optical drive
Graphics Controller
Intel Graphics Shared Video Memory (UMA) - up to 6 TOPS
1GbE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5, Wi-Fi 6E
(50/60 Hz)
OS Provided
Windows 11 Pro
Software Included
Activate your Microsoft 365 for a 30 day trial
3.6 cm x 17.8 cm x 18.2 cm
1.22 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
80.7 kg carbon emissions
Personal computer
AI Level
AI PC
Bundled Services
Product Form Factor
Micro
Built-in Devices
Internal aerial
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz (P-core) / 2.9 GHz (E-core)
Max Turbo Speed
5 GHz (P-core) / 4.4 GHz (E-core)
Number of Cores
14-core
CPU Qty
1
Max CPU Qty
1
14 Threads, 65W CPU
Chipset Type
Intel Q870
Intel AI Boost
NPU Performance Up To (TOPS)
13 TOPS
Total Processor Performance Up To (TOPS)
27 TOPS
AI Datatype Support on NPU
INT8
Sparsity Support
AI Software Frameworks Supported by NPU
DirectML, OpenVINO, WebNN, WindowsML, ONNX RT
Windows Studio Effects Support
Cache Memory
Installed Size
24 MB
Cache Per Processor
24 MB
RAM
Installed Size
Effective Memory Speed
5600 MT/s
Rated Memory Speed
5600 MT/s
SO-DIMM 262-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2
1 x 512 GB
Interface Type
PCI Express 4.0
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KM5221W Pro Wireless Keyboard and Mouse Combo
Interface (Bus) Type
M.2 2230
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wi-Fi 6E AX 211
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6E)
Dual stream (2x2)
Slots
2 (total) / 1 (free) x M.2 Card - 2230/2280 (for SSD) , 1 (total) / 0 (free) x M.2 Card - 2230 (for wireless module)
1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.2 Gen 2x2 , 1 x USB-C 3.2 Gen 2 , 4 x USB 3.2 Gen 2 (one of them with PowerShare) , 2 x USB 3.2 Gen 1 (one of them supports SmartPower On) , 1 x headphones/microphone , 3 x DisplayPort 1.4a
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
Pricing Type
Power adapter
AC 100-240 V (50/60 Hz)
Power Provided
180 watt
Operating System / Software
OS Provided
Windows 11 Pro
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
45.0306
Logistics (kg CO2e)
2.2596
Use (kg CO2e)
32.8449
EOL (kg CO2e)
0.5649
Total Carbon w/o Use Phase (kg CO2e)
47.8551
PAIA Version
GaBi version 1, 2024
3.6 cm
17.8 cm
18.2 cm
1.22 kg
10 °C
35 °C
20 - 80% (non-condensing)
Monitors (12)
JFKC Dell UltraSharp 24" 1920 x 1080 5 ms IPS In Stock £157.90
JFKC Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor In Stock £341.58
JFKC Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor In Stock £88.69
JFKC Dell UltraSharp U2724D - LED monitor - QHD - 27" In Stock £278.61
JFKC Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £139.87
JFKC Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £112.94
JFKC Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £135.97
JFKC Dell Pro E2425HM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £67.48
JFKC Dell P2424HT 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £275.46
JFKC Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £247.13
JFKC Dell Pro Plus P2425D 24" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor In Stock £184.04
JFKC Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £87.77
Accessories (1)
JFKC Dell OptiPlex Micro and Thin Client VESA Mount w/Adapter Bracket In Stock £26.71
Keyboards and Mice (4)
JFKC Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £44.32
JFKC Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £57.37
JFKC Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £35.11
JFKC Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £15.38
Other bundles (4)
JFKC Dell Slim DW316 USB External DVD Drive In Stock £36.19
JFKC Dell SB521A Magnetic Sound bar In Stock £30.78
JFKC Dell WEBCAM - WB3023 In Stock £47.02
JFKC Dell Dell Speakerphone SP3022 In Stock £61.06
Storage Type: SSD
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: Dell
Price Range Ex VAT: £750 - £1000
