The Dell Pro Max Micro FCM2250 delivers performance and versatility in an ultra small form factor. With a powerful Intel Core Ultra 7 processor, this personal computer is engineered to handle demanding tasks, featuring 20 cores and a maximum turbo speed of 5.3 GHz. The system is equipped with a responsive 30 MB cache and integrated audio through Realtek ALC3204, ensuring fluid processing and high definition sound. Supporting a range of connectivity options, the system is built with multiple USB 3.2 ports, including USB-C, alongside HDMI outputs for adaptable display connections. Its high-speed NVM Express SSD interface assures rapid data access and storage, further enhanced by security features like Trusted Platform Module (TPM). All of this is housed in a compact chassis designed for efficient performance in various environments, meeting the demands of both personal and professional use.
- Dell Pro Max Micro FCM2250 - micro - AI PC - Core Ultra 7 265 2.4 GHz - vPro Enterprise - 16 GB - SSD 1 TB
- Personal computer - micro - AI PC
- Bundled Services
- 3 Years Basic Onsite
- Platform Technology
- Intel vPro Enterprise
- Processor
- Intel Core Ultra 7 (Series 2) 265 / 2.4 GHz (up to 5.3 GHz, (20-core)
- Processor Main Features
- 20 Threads, 65W TDP
- Neural Processor Unit (NPU)
- Intel AI Boost - up to 13 TOPS
- Cache Memory
- 30 MB
- Cache Per Processor
- 30 MB
- RAM
- 16 GB (installed) / 64 GB (max) - DDR5 SDRAM - non-ECC
- Hard Drive
- SSD 1 TB - PCI Express 4.0 - M.2 2280 - Self-Encrypting Drive, NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- No optical drive
- Graphics Controller
- NVIDIA RTX A1000 - up to 8 TOPS
- Video Memory
- 8 GB GDDR6 SDRAM
- Networking
- 1GbE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5, Wi-Fi 6, Wi-Fi 7
- Power
- (50/60 Hz)
- OS Provided
- Windows 11 Pro
- Software Included
- Intel Rapid Storage Technology, Activate your Microsoft 365 for a 30 day trial
- Black
- 7.93 cm x 17.8 cm x 20.6 cm
- 1.89 kg
- Pricing Type
- Build To Plan (BTP)
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 183 kg carbon emissions
- Personal computer
- AI Level
- AI PC
- Bundled Services
- Product Form Factor
- Micro
- Built-in Devices
- Internal aerial
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
Processor / Chipset
- CPU
- Clock Speed
- 2.4 GHz (P-core) / 1.8 GHz (E-core)
- Max Turbo Speed
- 5.3 GHz (P-core) / 4.6 GHz (E-core)
- Number of Cores
- 20-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel W880
- Intel AI Boost
- NPU Performance Up To (TOPS)
- 13 TOPS
- Total Processor Performance Up To (TOPS)
- 33 TOPS
- AI Datatype Support on NPU
- INT8
- Sparsity Support
- AI Software Frameworks Supported by NPU
- DirectML, OpenVINO, WebNN, WindowsML, ONNX RT
- Windows Studio Effects Support
Cache Memory
- Installed Size
- 30 MB
- 30 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2800 MHz
- Rated Memory Speed
- 2800 MHz
- Form Factor
- SO-DIMM 262-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 1 TB
- Interface Type
- PCI Express 4.0
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 8 GB GDDR6 SDRAM
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
- Keyboard Name
- Dell KB216 Wired Keyboard
Mouse
- Mouse Name
- Dell MS116 USB Optical Mouse
- Interface (Bus) Type
- M.2 2230
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel WI-FI 7 BE200
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6), IEEE 802.11be (Wi-Fi 7)
- MU-MIMO Support, dual stream (2x2)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11be
- Slots
- 2 (total) / 1 (free) x M.2 Card - 2280 (for SSD) , 1 (total) / 0 (free) x M.2 Card - 2230 (for wireless module) , 2 PCIe 4.0 x8 - half-height
- 1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.2 Gen 2x2 (1 front) , 4 x USB 3.2 Gen 2 (2 front, 2 rear) (one of them with PowerShare) , 1 x USB-C 3.2 Gen 2 (1 rear) , 2 x USB 3.2 Gen 1 (2 rear) (one of them supports SmartPower On) , 1 x headphones/microphone , 3 x DisplayPort 1.4a , 4 x Mini DisplayPort 1.4a
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power adapter
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Power Provided
- 280 watt
Operating System / Software
- OS Provided
- Windows 11 Pro
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 63.318
- Logistics (kg CO2e)
- 3.66
- Use (kg CO2e)
- 114.741
- EOL (kg CO2e)
- 1.28
- Total Carbon w/o Use Phase (kg CO2e)
- 68.26
- PAIA Version
- GaBi version 1, 2024
- 7.93 cm
- 17.8 cm
- 20.6 cm
- 1.89 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
Accessories (2)
Dell Dual Monitor Stand - MDS19 | In Stock | £129.07 |
Dell OptiPlex Micro and Thin Client VESA Mount w/Adapter Bracket | In Stock | £26.71 |
Monitors (11)
Dell UltraSharp 24" 1920 x 1080 5 ms IPS | In Stock | £157.90 |
Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor | In Stock | £341.58 |
Dell UltraSharp U3824DW 38" 3840x1600 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £921.33 |
Dell UltraSharp U2724D - LED monitor - QHD - 27" | In Stock | £278.61 |
Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £139.87 |
Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £112.94 |
Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £135.97 |
Dell P2424HT 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £275.46 |
Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £487.37 |
Dell Pro Plus P2425D 24" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £184.04 |
Dell DELL ULTRASHARP 49 CURVED - U4924DW | In Stock | £1,046.07 |
Keyboards and Mice (6)
Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black | In Stock | £23.31 |
Dell KB-813 Smart Card Reader | In Stock | £45.62 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £44.32 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £28.14 |
Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot | In Stock | £35.11 |
Dell Dell Mobile Wireless Mouse - MS3320W - Black | In Stock | £15.38 |
Other bundles (4)
Dell Slim DW316 USB External DVD Drive | In Stock | £36.19 |
Dell SB521A Magnetic Sound bar | In Stock | £30.78 |
Dell WEBCAM - WB3023 | In Stock | £47.02 |
Dell Dell Speakerphone SP3022 | In Stock | £61.06 |
