Dell Pro Max Micro FCM2250 Intel Core Ultra 7-265 16GB 1TB SSD Windows 11 Professional
Quicklinx: JGD6WS00 Mfr#: JP46N
Processor Type: Core Ultra 7
Operating System: Windows 11 Pro
Hard Drive Capacity: 1TB
Storage Type: SSD
Processor Model: 265
  • IEEE 802.11n
25 In Stock
£1,626.88 ex VAT
£1,952.25 inc VAT
The Dell Pro Max Micro FCM2250 delivers performance and versatility in an ultra small form factor. With a powerful Intel Core Ultra 7 processor, this personal computer is engineered to handle demanding tasks, featuring 20 cores and a maximum turbo speed of 5.3 GHz. The system is equipped with a responsive 30 MB cache and integrated audio through Realtek ALC3204, ensuring fluid processing and high definition sound. Supporting a range of connectivity options, the system is built with multiple USB 3.2 ports, including USB-C, alongside HDMI outputs for adaptable display connections. Its high-speed NVM Express SSD interface assures rapid data access and storage, further enhanced by security features like Trusted Platform Module (TPM). All of this is housed in a compact chassis designed for efficient performance in various environments, meeting the demands of both personal and professional use.
Dell Pro Max Micro FCM2250 - micro - AI PC - Core Ultra 7 265 2.4 GHz - vPro Enterprise - 16 GB - SSD 1 TB
Personal computer - micro - AI PC
Bundled Services
3 Years Basic Onsite
Platform Technology
Intel vPro Enterprise
Intel Core Ultra 7 (Series 2) 265 / 2.4 GHz (up to 5.3 GHz, (20-core)
Processor Main Features
20 Threads, 65W TDP
Neural Processor Unit (NPU)
Intel AI Boost - up to 13 TOPS
Cache Memory
30 MB
Cache Per Processor
30 MB
RAM
16 GB (installed) / 64 GB (max) - DDR5 SDRAM - non-ECC
Hard Drive
SSD 1 TB - PCI Express 4.0 - M.2 2280 - Self-Encrypting Drive, NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
No optical drive
Graphics Controller
NVIDIA RTX A1000 - up to 8 TOPS
Video Memory
8 GB GDDR6 SDRAM
1GbE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5, Wi-Fi 6, Wi-Fi 7
(50/60 Hz)
OS Provided
Windows 11 Pro
Software Included
Intel Rapid Storage Technology, Activate your Microsoft 365 for a 30 day trial
7.93 cm x 17.8 cm x 20.6 cm
1.89 kg
Pricing Type
Build To Plan (BTP)
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
183 kg carbon emissions
Platform Technology
Personal computer
AI Level
AI PC
Bundled Services
Product Form Factor
Micro
Built-in Devices
Internal aerial
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.4 GHz (P-core) / 1.8 GHz (E-core)
Max Turbo Speed
5.3 GHz (P-core) / 4.6 GHz (E-core)
Number of Cores
20-core
CPU Qty
1
Max CPU Qty
1
20 Threads, 65W TDP
Chipset Type
Intel W880
Intel AI Boost
NPU Performance Up To (TOPS)
13 TOPS
Total Processor Performance Up To (TOPS)
33 TOPS
AI Datatype Support on NPU
INT8
Sparsity Support
AI Software Frameworks Supported by NPU
DirectML, OpenVINO, WebNN, WindowsML, ONNX RT
Windows Studio Effects Support
Cache Memory
Installed Size
30 MB
Cache Per Processor
30 MB
RAM
Installed Size
Effective Memory Speed
2800 MHz
Rated Memory Speed
2800 MHz
SO-DIMM 262-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2 2280
1 x 1 TB
Interface Type
PCI Express 4.0
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Memory
8 GB GDDR6 SDRAM
Video Interfaces
DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Wired Keyboard
Mouse
Mouse Name
Dell MS116 USB Optical Mouse
Interface (Bus) Type
M.2 2230
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel WI-FI 7 BE200
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6), IEEE 802.11be (Wi-Fi 7)
MU-MIMO Support, dual stream (2x2)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11be
Slots
2 (total) / 1 (free) x M.2 Card - 2280 (for SSD) , 1 (total) / 0 (free) x M.2 Card - 2230 (for wireless module) , 2 PCIe 4.0 x8 - half-height
1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.2 Gen 2x2 (1 front) , 4 x USB 3.2 Gen 2 (2 front, 2 rear) (one of them with PowerShare) , 1 x USB-C 3.2 Gen 2 (1 rear) , 2 x USB 3.2 Gen 1 (2 rear) (one of them supports SmartPower On) , 1 x headphones/microphone , 3 x DisplayPort 1.4a , 4 x Mini DisplayPort 1.4a
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
Pricing Type
Build To Plan (BTP)
Power adapter
AC 100-240 V (50/60 Hz)
Power Provided
280 watt
Operating System / Software
OS Provided
Windows 11 Pro
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
63.32
Logistics (kg CO2e)
3.66
Use (kg CO2e)
114.74
EOL (kg CO2e)
1.28
Total Carbon w/o Use Phase (kg CO2e)
68.26
PAIA Version
GaBi version 1, 2024
7.93 cm
17.8 cm
20.6 cm
1.89 kg
35 °C
10 - 90% (non-condensing)
Accessories (2)
JGD6 Dell Dual Monitor Stand - MDS19 In Stock £129.07
JGD6 Dell OptiPlex Micro and Thin Client VESA Mount w/Adapter Bracket In Stock £26.71
Monitors (11)
JGD6 Dell UltraSharp 24" 1920 x 1080 5 ms IPS In Stock £175.51
JGD6 Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor In Stock £341.58
JGD6 Dell UltraSharp U3824DW 38" 3840x1600 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £963.97
JGD6 Dell UltraSharp U2724D - LED monitor - QHD - 27" In Stock £250.76
JGD6 Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £139.87
JGD6 Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £119.24
JGD6 Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £135.97
JGD6 Dell P2424HT 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £275.51
JGD6 Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £518.22
JGD6 Dell Pro Plus P2425D 24" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor In Stock £175.66
JGD6 Dell UltraSharp U4924DW 49" 5120x1440 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor In Stock £1,033.11
Keyboards and Mice (6)
JGD6 Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black In Stock £17.52
JGD6 Dell KB-813 Smart Card Reader In Stock £42.82
JGD6 Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £44.32
JGD6 Dell MS5120W Mobile Pro Wireless Mouse In Stock £20.80
JGD6 Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £43.95
JGD6 Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £11.66
Other bundles (3)
JGD6 Dell SB521A Magnetic Sound bar In Stock £30.78
JGD6 Dell WEBCAM - WB3023 In Stock £47.02
JGD6 Dell Dell Speakerphone SP3022 In Stock £61.06
Storage Type: SSD
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: Dell
Price Range Ex VAT: £1500+
