Dell Dell Pro KM5221W - Keyboard and mouse set - wireless
Quicklinx: H4RSWS00 Mfr#: KM5221W-WH-UK
33 In Stock
£30.09 ex VAT
£36.10 inc VAT
Dell Pro Wireless Keyboard and Mouse - KM5221W - UK (QWERTY) - White.
  • Productivity at your fingertips
    Enhance your all-day productivity with this RF 2.4GHz wireless keyboard and mouse combo. With 12 programmable keys and 1 programmable scroll wheel click, you can gain quick access to your frequently used applications, folders and functions. The full-sized wireless keyboard comes with a dedicated numeric pad, function keys, and programmed pre-sets that can enhance your efficiency.
  • Easy management
    Easily navigate across monitors of varying resolutions at home or in the office. Dell Peripheral Manager (DPM) software enables you to manage your input devices and adjust to your preferred preset DPIs at 1000, 1600, 2400, or 4000. With DPM, you can customize shortcut keys and buttons, pair devices, adjust DPI, check battery and connectivity status, and update to the latest firmware.
  • Work in comfort
    Work with one of the quietest wireless keyboards whether on a conference call or in proximity with others. Symmetrically designed, the wireless mouse is great for both left and right-handed users. The tilt legs offer two adjustable angles for the keyboard, giving you the flexibility to choose your preferred typing position.
  • Durable and secure
    The Dell Pro Wireless Keyboard and Mouse is built to last with one of the industry's leading battery lives at up to 36 months. Rest assured that this keyboard and mouse combo has been rigorously tested to ensure seamless connection to your Dell PC. The keyboard offers 128-bit AES (Advanced Encryption Standard) encryption protecting your data transmission across your PCs and devices, providing you with a secure connection while typing.
Dell Pro KM5221W - keyboard and mouse set - QWERTY - UK - white Input Device
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Mute, volume -, volume +
Pointing Device
Mouse - wireless - optical
Buttons Qty
3
Performance
Realtime sensitivity switching 1000/1600/2400/4000 dpi
White
3-year warranty
2.4 GHz
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 43.3 cm x 12.3 cm x 3.4 cm / 400 g , Mouse: 6.196 cm x 11.532 cm x 3.88 cm / 65 g
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Plunger
Pointing Device
Mouse - wireless
Buttons Qty
3
Movement Detection Technology
Optical
Movement Resolution
4000 dpi
Batteries:
1
Performance
Supported Battery Type
AA x 1
White
AA battery, 2 AAA batteries
AES-128
Included Software
Dell Peripheral Manager (Windows only)
Apple MacOS, Android, Google Chrome OS, Microsoft Windows 7 / 8.1 / 10, Red Hat Enterprise Linux 8.0, Ubuntu 18.04, Windows 11
AAA type
Installed Qty
2
Run Time (Up To)
36 months
Limited warranty - advanced exchange programme - 3 years
Brand: Dell
