Productivity at your fingertips
Enhance your all-day productivity with this RF 2.4GHz wireless keyboard and mouse combo. With 12 programmable keys and 1 programmable scroll wheel click, you can gain quick access to your frequently used applications, folders and functions. The full-sized wireless keyboard comes with a dedicated numeric pad, function keys, and programmed pre-sets that can enhance your efficiency. -
Easy management
Easily navigate across monitors of varying resolutions at home or in the office. Dell Peripheral Manager (DPM) software enables you to manage your input devices and adjust to your preferred preset DPIs at 1000, 1600, 2400, or 4000. With DPM, you can customize shortcut keys and buttons, pair devices, adjust DPI, check battery and connectivity status, and update to the latest firmware. -
Work in comfort
Work with one of the quietest wireless keyboards whether on a conference call or in proximity with others. Symmetrically designed, the wireless mouse is great for both left and right-handed users. The tilt legs offer two adjustable angles for the keyboard, giving you the flexibility to choose your preferred typing position. -
Durable and secure
The Dell Pro Wireless Keyboard and Mouse is built to last with one of the industry's leading battery lives at up to 36 months. Rest assured that this keyboard and mouse combo has been rigorously tested to ensure seamless connection to your Dell PC. The keyboard offers 128-bit AES (Advanced Encryption Standard) encryption protecting your data transmission across your PCs and devices, providing you with a secure connection while typing.
- Dell Pro KM5221W - keyboard and mouse set - QWERTY - UK - white Input Device
- Keyboard and mouse set
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Mute, volume -, volume +
- Pointing Device
- Mouse - wireless - optical
- Buttons Qty
- 3
- Performance
- Realtime sensitivity switching 1000/1600/2400/4000 dpi
- White
- Bundled Services
- 3 years NBD Advance Exchange
- Interface
- 2.4 GHz
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 43.3 cm x 12.3 cm x 3.4 cm / 400 g , Mouse: 6.196 cm x 11.532 cm x 3.88 cm / 65 g
- Bundled Services
- Wireless
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Plunger
Pointing Device
- Mouse - wireless
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Movement Resolution
- 4000 dpi
- Batteries:
- 1
- Performance
- Supported Battery Type
- AA x 1
- White
- Included Accessories
- AA battery, 2 AAA batteries
- AES-128
- Included Software
- Dell Peripheral Manager (Windows only)
- OS Required
- Apple MacOS, Android, Google Chrome OS, Microsoft Windows 7 / 8.1 / 10, Red Hat Enterprise Linux 8.0, Ubuntu 18.04, Windows 11
- AAA type
- Installed Qty
- 2
- Run Time (Up To)
- 36 months
