The Dell Pro Dock WD25 is designed to enhance productivity with robust connectivity options. Featuring a USB-C cable that integrates seamlessly with various devices, this docking station supports multiple interface types including USB 3.2 Gen 2, 2.5G Gigabit Ethernet, HDMI, and DisplayPort. With the capability to connect up to four displays, including support for 4K, 5K, and 6K resolutions, the dock ensures an immersive visual experience. It also provides significant power delivery, offering up to 100 W for Dell systems and 96 W for others, making it a versatile solution for users needing both connectivity and power. Equipped with features like wake on LAN and MAC address pass-through, this docking station is ideal for both professional and personal setups, delivering reliable performance in various environments, from home offices to corporate settings.
- Dell Pro Dock WD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- 20.5 cm x 9 cm x 3.5 cm
- 550 g
- Networking
- Gigabit Ethernet, 2.5 Gigabit Ethernet
- Power
- Power adapter AC 100-240 V (50 - 60 Hz) 130 Watt Power Provided (19.5 V)
- Pricing Type
- BTO
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
- Product Type
- Docking station
- 20.5 cm
- 9 cm
- 3.5 cm
- 550 g
Video
- Max Resolution Details
- 4K - 60 Hz (Quad Display) , 5K - 60 Hz (Dual Display) , 6K - 60 Hz (Single Display)
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2 x display / video - DisplayPort - 20 pin DisplayPort (1.4) , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.2 Gen 2/DisplayPort 1.4 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 4 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x network - 2.5G Gigabit Ethernet - RJ-45
- Cables Included
- 1 x USB-C cable - integrated - 90 cm
- Preboot Execution Environment (PXE) support, Kernel Direct Memory Access (DMA) protection, 100W power delivery to Dell systems, 96W power delivery to non-Dell systems, 2 LED indicators, wake on LAN, MAC address pass-through, security lock slot (cable lock sold separately), Dell Power Button Sync
- Security Slot Type
- Noble Wedge security slot / Kensington security slot
- DisplayPort 1.4
- Pricing Type
- BTO
- Power Device
- Power adapter
- Voltage Required
- AC 100-240 V (50 - 60 Hz)
- Power Provided
- 130 Watt
- Voltage Provided
- 19.5 V
- OS Required
- Ubuntu 24.04, Red Hat Enterprise Linux, Google Chrome OS, Windows 10, Windows 11
- Bundled Services
- 0 °C
- 35 °C
