The Dell Pro E2725HM is designed to elevate the desktop experience with its 27-inch Full HD display. Featuring a native resolution of 1920 x 1080, this monitor delivers clarity and detail characterized by its 300 cd/m² brightness and a contrast ratio of 1000:1. With a wide horizontal and vertical viewing angle of 178 degrees, users can enjoy vibrant colors and clear images from almost any position. Various features like Dell Easy Arrange and Eye Comfort Mode make managing multiple applications and ensuring visual comfort effortless. The anti-glare and 3H hard coating help reduce reflections, making it suitable for extended use. Additionally, the monitor supports advanced connectivity options through its DisplayPort, HDMI, and VGA inputs while maintaining a sleek design with a 3-sided bezel-less screen.
- Dell Pro E2725HM - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2186816
- Energy Class
- Class D
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931)
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- 61.11 cm x 18.829 cm x 45.431 cm
- 4.55 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 171 kg carbon emissions
- Plug and Play, RoHS, NFPA 99, DisplayPort 1.2, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Pixel Per Inch
- 81
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 110 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
- 61.11 cm x 18.829 cm x 45.431 cm - with stand
- 4.55 kg
- HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, cable management system
- Cables Included
- 1 x DisplayPort 1.2 cable - DisplayPort to DisplayPort - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 15 kWh/1000h
- Power Consumption (Typical)
- 14.76 Watt
- Power Consumption (Max)
- 28 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 61.11 cm - depth: 18.829 cm - height: 45.431 cm - weight: 4.55 kg , Without stand - width: 61.11 cm - depth: 4.922 cm - height: 36.186 cm - weight: 3.57 kg
- Shipping Weight
- 6.69 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Manufacturing (kg CO2e)
- 81.23
- Logistics (kg CO2e)
- 12.48
- Use (kg CO2e)
- 72.85
- EOL (kg CO2e)
- 4.28
- Total Carbon w/o Use Phase (kg CO2e)
- 98.15
- PAIA Version
- GaBi version 1
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Dual Monitor Stand - MDS19 | In Stock | £129.07 |
