Dell DELL PC14250 U7-265U 16G/512GB W11P
Quicklinx: JG1XWS00 Mfr#: C8CTW
Screen Size: 14in
Processor Model: 265U
Operating System: Windows 11 Pro
Hard Drive Capacity: 512GB
Graphics: Intel Graphics
  • IEEE 802.11n
More than 50 In Stock
£978.47 ex VAT
£1,174.16 inc VAT
The Dell Pro 14 PC14250 combines performance and portability, making it an ideal choice for professionals on the go. With a powerful Intel Core Ultra 7 processor featuring 12 cores and a maximum turbo speed of 5.2 GHz, this notebook is designed to handle demanding tasks with ease. The 16 GB of DDR5 RAM ensures smooth multitasking, while the 512 GB SSD provides ample storage and fast data access. Equipped with a 14-inch Full HD Plus display, users can enjoy vivid graphics and clear visuals, backed by IPS technology for wider viewing angles. This notebook also features audio capabilities, including dual array microphones and stereo speakers that support high definition audio for an immersive sound experience. The integrated webcam with face recognition and infrared capability enhances security and usability for video conferencing. With a robust set of connectivity options including USB-C and HDMI ports, as well as wireless protocols like Wi-Fi 6E and Bluetooth, the Dell Pro 14 PC14250 is well-equipped to support modern connectivity needs.
Dell Pro 14 PC14250 - AI PC - 14" - Intel Core Ultra 7 - 265U - vPro Enterprise - 16 GB RAM - 512 GB SSD
Notebook - AI PC
Operating System
Win 11 Pro
Platform Technology
Intel vPro Enterprise
Intel Core Ultra 7 (Series 2) - 265U / 2.1 GHz, up to 5.3 GHz / 12 MB Cache
Neural Processor Unit (NPU)
Intel AI Boost - up to 12 TOPS
16 GB DDR5 (1 x 16 GB)
Storage
512 GB SSD - NVMe
Display
14" 1920 x 1200 / Full HD Plus @ 60 Hz - 162 ppi
Graphics
Intel Graphics
Keyboard Backlight
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
3-cell
Security
Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Platinum silver
31.37 cm x 22.53 cm x 2.037 cm
1.36 kg
Pricing Type
Build To Stock (BTS)
Manufacturer Selling Program
Dell Smart Selection
Environmental Standards
EPEAT Gold
Carbon Footprint
106 kg carbon emissions
Bundled Services
1 Year Basic Onsite
Notebook
AI Level
AI PC
Operating System
Windows 11 Pro
Processor / Chipset
CPU
Intel Core Ultra 7 (Series 2) 265U / 2.1 GHz
Max Turbo Speed
5.3 GHz
Number of Cores
12-core
Performance Cores
2
Efficient Cores
10
Cache
12 MB
Platform Technology
14 Threads
Intel AI Boost
NPU Performance Up To (TOPS)
12 TOPS
AI Datatype Support on NPU
INT8
Sparsity Support
AI Software Frameworks Supported by NPU
DirectML, OpenVINO, WindowsML, ONNX RT
Windows Studio Effects Support
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR5 SDRAM
Speed
5600 MT/s
Rated Speed
5600 MT/s
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2230 PCIe 4.0 - NVM Express (NVMe)
Display
14" - IPS
Resolution
1920 x 1200 (Full HD Plus)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
162
Image Aspect Ratio
16:10
Image Brightness
300 cd/m²
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+85 / -85
Colour Gamut
45% NTSC
Anti-glare, 35 ms response rate, 0.1571 mm pixel pitch
Audio & Video
Graphics Processor
Intel Graphics
Camera
Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
Resolution
2.07 Megapixel (standard), 0.23 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
1920 x 1080
Frame Rate
30 frames per second
Camera Features
Face recognition, IR camera, RGB camera, Temporal Noise Reduction, 86.6 degrees (IR camera), 80.2 degrees, camera shutter
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio, Wave MAXXAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Copilot key
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6E AX 211 - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H-CG
Dual stream (2x2)
3-cell
210 g
55 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 watt
Connections & Expansion
Interfaces Details
HDMI , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 , USB 3.2 Gen 1 (PowerShare) , LAN (RJ-45) , Headphone/microphone combo jack
Software
Software Included
Intel Rapid Storage Technology, Intel Connectivity Performance Suite, Dell Additional Softwares, Activate your Microsoft 365 for a 30 day trial
Platinum silver
Surface Finish
Metallic
Security
ExpressCharge, ExpressChargeBoost
Theft/Intrusion Protection
Security Slot Type
Wedge-shaped security slot
USB-C power adapter, POD Label
FIPS 140-2, TCG Certified
Pricing Type
1.36 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
Carbon Footprint
Manufacturing (kg CO2e)
74.518
Logistics (kg CO2e)
3.498
Use (kg CO2e)
26.06
EOL (kg CO2e)
1.484
Total Carbon w/o Use Phase (kg CO2e)
81
PAIA Version
GaBi version 1, 2024
Bundled Services
1 Year Basic Onsite
90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
JG1X Dell DELL PRO DOCK - WD25 In Stock £148.54
JG1X Dell Pro Smart Dock SD25 - docking station In Stock £206.78
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
JG1X Dell 1Y BASIC ONSITE TO 3Y BASIC ONSITE In Stock £37.26
Other bundles (28)
JG1X Dell Slim DW316 USB External DVD Drive In Stock £40.60
JG1X Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £8.69
JG1X Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £12.80
JG1X Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black In Stock £23.31
JG1X Dell KB-813 Smart Card Reader In Stock £45.62
JG1X Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £25.61
JG1X Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £44.32
JG1X Dell SB521A Magnetic Sound bar In Stock £30.78
JG1X Dell MS5120W Mobile Pro Wireless Mouse In Stock £28.14
JG1X Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £43.18
JG1X Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £48.55
JG1X Dell WEBCAM - WB3023 In Stock £47.02
JG1X Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £15.38
JG1X Dell Dell Speakerphone SP3022 In Stock £67.46
JG1X Dell UltraSharp 24" 1920 x 1080 5 ms IPS In Stock £157.91
JG1X Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor In Stock £341.58
JG1X Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor In Stock £88.69
JG1X Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £165.88
JG1X Dell UltraSharp U2724D - LED monitor - QHD - 27" In Stock £278.61
JG1X Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £139.87
JG1X Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £119.24
JG1X Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £209.52
JG1X Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £487.37
JG1X Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £186.11
JG1X Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £259.41
JG1X Dell SE2225HM 2" 1920x1080 5ms VGA HDMI LED Monitor In Stock £57.96
JG1X Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £87.77
JG1X Dell UltraSharp U2724DE 27" 2560x1440 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £378.44
Screen Size: 14in
Brand: Dell
Price Range Ex VAT: £750 - £1000
