Dell DELL MEMORY 16GB DDR4 SODIMM 3200MHZ
Quicklinx: H8L4WS00 Mfr#: AB371022
More than 50 In Stock
£73.09 ex VAT
£87.70 inc VAT
Upgrading your computer systems with Dell memory is the perfect way to maximize system uptime and ensure unmatched compatibility, reliability, and performance.
Dell - DDR4 - module - 16 GB - SO-DIMM 260-pin - 3200 MHz / PC4-25600 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
3200 MHz (PC4-25600)
Single rank, unbuffered
Voltage
1.2 V
DELL AB371022, DELL SNP1CXP8C/16G
Pricing Type
Upgrade
16 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Module Configuration
2048 x 64
Chips Organization
X8
Voltage
1.2 V
Pricing Type
Upgrade
Brand: Dell
