Upgrading your computer systems with Dell memory is the perfect way to maximize system uptime and ensure unmatched compatibility, reliability, and performance.
- Dell - DDR4 - module - 16 GB - SO-DIMM 260-pin - 3200 MHz / PC4-25600 - unbuffered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 3200 MHz (PC4-25600)
- Single rank, unbuffered
- Voltage
- 1.2 V
- OEM Manufacturer Equivalent Part Number
- DELL AB371022, DELL SNP1CXP8C/16G
- Pricing Type
- Upgrade
- Limited lifetime warranty
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Speed
- Non-ECC
- Module Configuration
- 2048 x 64
- Chips Organization
- X8
- Voltage
- 1.2 V
- Pricing Type
- Upgrade
